Aqara E1 Roller shade: Position entity no longer provided by ZHA?
I don’t know when it started, but my Aqara Roller Shade drivers now only have the up/down control showing up as active on the dashboard. The previously working position slider is now inactive and when entering it shows:
This entity is no longer being provided by the zha integration. If the entity is no longer in use, delete it in settings.
To be fair, I can still control the position when entering the up/down control and switch it to slider mode. But is it possible to enable the old behaviour again?
Yeah, that would be great. cause it shows wrong state on the shade. after some time after closing the shade it shows as open. :neutral_face:
did you get this to work?
Same issue here
Same issue here. Does anyone know how to get it back? It’s stopping me from using Adaptive Cover.
I still have the problem. Did you fix it ?
