Aqara FP300 Goes Offline in HA after 15 minutes but still active in Apple Home
Since the Matter Server upgraded to v9.0.0 and above, we’ve noticed an issue where the Aqara FP300 Presence Sensor will show online when the Matter Server starts, for 15 minutes and will then go offline.
However, the device is still online and active in Apple Home.
The device was added in Apple Home first, then into Home Assistant. It is connected to the primary IKEA Thread boarder router, with 3 other boarder routers in the network.
Most other devices (all IKEA temperature and air quality sensors) stay connected. Sometimes the odd one will drop off too.
This is “resolved” by rebooting the server or restarting the Matter Server app.
Then, 15 minutes later it goes again. This is the log when filtering for the device ID:
2026-08-23 20:29:47.459 INFO   CaseClient           @1:b8•90fd New session with @1:b8 4↔2 address: udp://[fd30:2813:8eba:1:9e90:ab4:a53e:d275]:5540 fabric: 41c417db98d0fc26 (#1) SII: 6s SAI: 1.1s SAT: 500ms DMRev: 18 IMRev: 12 spec: 0x1040100 maxPaths: 5 CATs:
2026-08-23 20:29:47.459 INFO   ClientNode           server-2-134b.@1:b8 is online
2026-08-23 20:29:47.461 INFO   IpServiceStatus      @1:b8 Connected
2026-08-23 20:29:47.470 INFO   ClientInteraction    Read » @1:b8•90fd⇵38d3 bootstrap attributes: 1 events: 1
2026-08-23 20:29:48.800 INFO   ClientInteraction    Read « @1:b8•90fd⇵38d3 2↔2 attributes: 50 events: 0
2026-08-23 20:29:48.802 INFO   ClientInteraction    Subscribe » @1:b8•90fd⇵38d5 min: 0 max: 5m attributes: 1 events: 1
2026-08-23 20:29:54.971 INFO   ClientInteraction    Subscription successful « @1:b8•90fd⇵38d5 2↔3+1 id: 66491bcc interval: 5m timeout: 5m 38s
2026-08-23 20:29:54.971 NOTICE Controller~ndHandler Node @1:b8 availability changed to true (state: Connected)
2026-08-23 20:29:54.972 INFO   WebSocketC~erHandler [0] Node @1:b8 availability changed to true
2026-08-23 20:29:54.972 INFO   WebSocketC~erHandler [1] Node @1:b8 availability changed to true
2026-08-23 20:37:06.942 INFO   ClientInteraction    Read » @1:b8•90fd⇵38ec attributes: 3
2026-08-23 20:37:10.691 INFO   ClientInteraction    Read « @1:b8•90fd⇵38ec attributes: 3 events: 0
2026-08-23 20:38:30.969 INFO   InteractionMessenger @1:b8•90fd⇵b6b3 Error sending success after final data report chunk [peer-unresponsive] Peer is no longer responding to active session (timed out after 1m 20s)
2026-08-23 20:40:18.318 INFO   ClientInteraction    Read » @1:b8•90fd⇵38ed attributes: 1
2026-08-23 20:40:18.418 INFO   ClientInteraction    Read » @1:b8•90fd⇵38ee attributes: 1
2026-08-23 20:41:50.006 INFO   ClientNode           server-2-134b.@1:b8 is offline
2026-08-23 20:42:40.984 INFO   IpServiceStatus      @1:b8 Resolving (address is unreachable)
2026-08-23 20:42:40.986 INFO   PeerConnection       @1:b8•unsecured#d715ec26dcacf800⇵38ef ip://[fd30:2813:8eba:1:9e90:ab4:a53e:d275]:5540 Connecting addr #: 1 attempt #: 1 connect time: 2ms addr time: 0 thread:25:connect
2026-08-23 20:42:49.378 INFO   ClientSubscription   Subscription 66491bcc to peer @1:b8 timed out after 5m 38s
2026-08-23 20:42:49.378 INFO   ClientSubscription   Replacing subscription to @1:b8 after loss
2026-08-23 20:42:49.379 INFO   ClientSubscription   Failed to probe reachability of peer @1:b8, resubscribe with new session
2026-08-23 20:42:57.592 INFO   Session              @1:b8•90fd Session ended
2026-08-23 20:44:50.009 INFO   WebSocketC~erHandler [0] Node @1:b8 availability changed to false
2026-08-23 20:44:50.008 WARN   Controller~ndHandler Node @1:b8 offline grace period expired, marking unavailable
2026-08-23 20:44:50.009 INFO   WebSocketC~erHandler [6] Node @1:b8 availability changed to false
Has anyone else faced this issue and managed to resolve it? Or could it be an issue with the Matter Server?
HA Version Details:
Core 2026.8.3
Supervisor 2026.07.5
Operating System 18.2
Frontend 20260729.7
Matter Server Version: 9.2.0
Logs without filtering from the point of the device becoming marked as unavailable:
2026-08-23 20:41:50.008 ERROR  WebSocketC~erHandler [0] WebSocket error response (read_attribute) 1e04f198dab2496ab0a9713a07cf3e1e [peer-unresponsive] Peer is no longer responding to active session (timed out after 1m 31s)
  at MessageExchange.#sentMessageAckFailure (/app/node_modules/@matter/protocol/src/protocol/MessageExchange.ts:748:29)
  at MessageExchange.#retransmitMessage (/app/node_modules/@matter/protocol/src/protocol/MessageExchange.ts:908:22)
  at StandardTimer.callback (/app/node_modules/@matter/protocol/src/protocol/MessageExchange.ts:960:18)
  at Timeout.<anonymous> (/app/node_modules/@matter/general/src/time/StandardTime.ts:122:18)
  at listOnTimeout (node:internal/timers:635:17)
  at process.processTimers (node:internal/timers:571:7)
2026-08-23 20:41:50.014 ERROR  WebSocketC~erHandler [0] WebSocket error response (read_attribute) d0c0abc0909c48caa14c806e0043a7a5 [closed] Channel is closed
    at DataReadQueue.read (/app/node_modules/@matter/general/src/util/DataReadQueue.ts:23:19)
    at MessageExchange.#nextMessage (/app/node_modules/@matter/protocol/src/protocol/MessageExchange.ts:843:42)
    at MessageExchange.nextMessage (/app/node_modules/@matter/protocol/src/protocol/MessageExchange.ts:808:31)
    at InteractionClientMessenger.#nextMessage (/app/node_modules/@matter/protocol/src/interaction/InteractionMessenger.ts:162:45)
    at InteractionClientMessenger.anyNextMessage (/app/node_modules/@matter/protocol/src/interaction/InteractionMessenger.ts:158:21)
    at InteractionClientMessenger.waitFor (/app/node_modules/@matter/protocol/src/interaction/InteractionMessenger.ts:850:36)
    at InteractionClientMessenger.readDataReports (/app/node_modules/@matter/protocol/src/interaction/InteractionMessenger.ts:875:50)
    at readDataReports.next (<anonymous>)
    at ClientInteraction.read (/app/node_modules/@matter/protocol/src/action/client/ClientInteraction.ts:265:26)
    at async ClientStructure.mutate (/app/node_modules/@matter/node/src/node/client/ClientStructure.ts:258:30)
  Caused by: [peer-unresponsive] Peer is no longer responding to active session (timed out after 1m 31s)
2026-08-23 20:41:50.773 INFO   ClientEventEmitter   Received event electricalEnergyMeasurement.cumulativeEnergyMeasured on server-2-134b.@1:9e.ep2 energyImported: { energy: 14331869, startTimestamp: 946684806, endTimestamp: 956256978, startSystime: 6964, endSystime: 9572179135 } energyExported: { energy: 0 }
2026-08-23 20:41:53.358 INFO   ClientEventEmitter   Received event electricalEnergyMeasurement.cumulativeEnergyMeasured on server-2-134b.@1:9d.ep2 energyImported: { energy: 2966853, startTimestamp: 946684800, endTimestamp: 956715193, startSystime: 1768, endSystime: 10030394755 } energyExported: { energy: 0 }
2026-08-23 20:42:23.601 INFO   WebSocketC~erHandler [3] WebSocket connection closed
2026-08-23 20:42:23.970 INFO   WebSocketC~erHandler [4] WebSocket connection established
2026-08-23 20:42:23.977 INFO   WebSocketC~erHandler WebSocket server start_listening
2026-08-23 20:42:23.977 INFO   WebSocketC~erHandler WebSocket server start_listening. Returned 23 nodes
2026-08-23 20:42:42.187 INFO   ClientEventEmitter   Received event electricalEnergyMeasurement.cumulativeEnergyMeasured on server-2-134b.@1:9c.ep2 energyImported: { energy: 10342015, startTimestamp: 946684800, endTimestamp: 956715613, startSystime: 1821, endSystime: 10030814106 } energyExported: { energy: 0 }
2026-08-23 20:42:50.769 INFO   ClientEventEmitter   Received event electricalEnergyMeasurement.cumulativeEnergyMeasured on server-2-134b.@1:9e.ep2 energyImported: { energy: 14331869, startTimestamp: 946684806, endTimestamp: 956257038, startSystime: 6964, endSystime: 9572239135 } energyExported: { energy: 0 }
2026-08-23 20:42:53.357 INFO   ClientEventEmitter   Received event electricalEnergyMeasurement.cumulativeEnergyMeasured on server-2-134b.@1:9d.ep2 energyImported: { energy: 2966853, startTimestamp: 946684800, endTimestamp: 956715253, startSystime: 1768, endSystime: 10030454755 } energyExported: { energy: 0 }
2026-08-23 20:43:02.177 INFO   WebSocketC~erHandler [4] WebSocket connection closed
2026-08-23 20:43:02.516 INFO   WebSocketC~erHandler [5] WebSocket connection established
2026-08-23 20:43:02.535 INFO   WebSocketC~erHandler WebSocket server start_listening
2026-08-23 20:43:02.536 INFO   WebSocketC~erHandler WebSocket server start_listening. Returned 23 nodes
2026-08-23 20:43:42.174 INFO   ClientEventEmitter   Received event electricalEnergyMeasurement.cumulativeEnergyMeasured on server-2-134b.@1:9c.ep2 energyImported: { energy: 10342073, startTimestamp: 946684800, endTimestamp: 956715673, startSystime: 1821, endSystime: 10030874106 } energyExported: { energy: 0 }
2026-08-23 20:43:50.961 INFO   ClientEventEmitter   Received event electricalEnergyMeasurement.cumulativeEnergyMeasured on server-2-134b.@1:9e.ep2 energyImported: { energy: 14331869, startTimestamp: 946684806, endTimestamp: 956257098, startSystime: 6964, endSystime: 9572299135 } energyExported: { energy: 0 }
2026-08-23 20:43:53.361 INFO   ClientEventEmitter   Received event electricalEnergyMeasurement.cumulativeEnergyMeasured on server-2-134b.@1:9d.ep2 energyImported: { energy: 2966853, startTimestamp: 946684800, endTimestamp: 956715313, startSystime: 1768, endSystime: 10030514755 } energyExported: { energy: 0 }
2026-08-23 20:43:57.236 INFO   WebSocketC~erHandler [5] WebSocket connection closed
2026-08-23 20:43:57.515 INFO   WebSocketC~erHandler [6] WebSocket connection established
2026-08-23 20:43:57.526 INFO   WebSocketC~erHandler WebSocket server start_listening
2026-08-23 20:43:57.526 INFO   WebSocketC~erHandler WebSocket server start_listening. Returned 23 nodes
2026-08-23 20:44:02.894 INFO   ThreadDiag~csService no source xp=694DDEB4B1A84AC8 -> partial(no_credentials)
2026-08-23 20:44:02.894 INFO   ThreadDiag~csService no source xp=29BCB4CF22192D08 -> partial(no_credentials)
2026-08-23 20:44:10.989 ERROR  WebSocketC~erHandler [0] WebSocket error response (read_attribute) 028a43bea8d943faacd464d2d4d9350a [aborted] Operation aborted
    at abort.throwIfAborted (/app/node_modules/@matter/general/src/util/Abort.ts:215:21)
    at Peer.connect (/app/node_modules/@matter/protocol/src/peer/Peer.ts:454:24)
    at runNextTicks (node:internal/process/task_queues:65:5)
    at process.processTimers (node:internal/timers:568:9)
    at async PeerExchangeProvider.connect (/app/node_modules/@matter/protocol/src/peer/PeerExchangeProvider.ts:59:9)
    at async PeerExchangeProvider.initiateExchange (/app/node_modules/@matter/protocol/src/peer/PeerExchangeProvider.ts:83:17)
    at async InteractionClientMessenger.create (/app/node_modules/@matter/protocol/src/interaction/InteractionMessenger.ts:925:26)
    at async ClientInteraction.#begin (/app/node_modules/@matter/protocol/src/action/client/ClientInteraction.ts:1113:29)
  Caused by: [peer-unreachable] Peer has been unreachable for 1m 30s
    at abort.timeoutHandler (/app/node_modules/@matter/protocol/src/peer/Peer.ts:447:27)
    at abort.timeoutHandler (/app/node_modules/@matter/general/src/util/Abort.ts:102:34)
    at StandardTimer.callback (/app/node_modules/@matter/general/src/util/Abort.ts:126:37)
2026-08-23 20:44:10.991 ERROR  WebSocketC~erHandler [0] WebSocket error response (read_attribute) 41412d59583a49b2b6db1f658b234011 [aborted] Operation aborted
    at async ClientInteraction.read (/app/node_modules/@matter/protocol/src/action/client/ClientInteraction.ts:255:31)
2026-08-23 20:44:42.171 INFO   ClientEventEmitter   Received event electricalEnergyMeasurement.cumulativeEnergyMeasured on server-2-134b.@1:9c.ep2 energyImported: { energy: 10342087, startTimestamp: 946684800, endTimestamp: 956715733, startSystime: 1821, endSystime: 10030934106 } energyExported: { energy: 0 }
Hi there, could you reach out to our support team at [email protected] so we can look into this for you?
