Hi everyone,
I’m using a 3-gang Aqara H1 switch (neutral, EU version) with Zigbee2MQTT, and I’ve configured it as follows:
- Gang 1 and 2 are in relay mode, directly controlling downlights.
- Gang 3 is in decoupled mode, where it no longer controls the power to the light but instead triggers a Home Assistant automation to turn on/off a smart light.
The issue I’m facing is with the LED indicator on the decoupled gang (Gang 3):
- The indicator LED is always on, regardless of the actual state of the light it’s meant to control.
- Ideally, I’d like the LED to reflect the state of the smart light—i.e., turn on when the light is on, and off when the light is off.
My questions:
- Is there a way to control the LED state of an individual gang on the Aqara H1 via Zigbee2MQTT or Home Assistant?
- Can the LED be synced with the state of an entirely separate light entity (since the button is decoupled)?
- If not natively supported, is there a workaround—e.g., setting LED state via MQTT commands or using automation triggers to toggle the LED based on the smart light state?
Any insights or examples would be really helpful! I’d prefer not to confuse guests by having the LED always on even when the light isn’t.
Thanks!
