Aqara H1 Wireless
After upgrading to 2026.08 the custom quirk below no longer is supported I have the WRS-R02-G or a lumi.remote.b28ac1 (same as white just grey) model which is one of the variants in the script that is now no longer supported in the default quirk in HA with ZHA.
Is there any way to update this to work with the new version or get the default one to see it?
“”“Aqara H1-series wireless remote.”“”
from zigpy.profiles import zha
import zigpy.types as t
from zigpy.zcl.clusters.general import Basic, Identify, LevelControl, OnOff, PowerConfiguration, MultistateInput
from zigpy.zcl.clusters.lighting import Color
from zhaquirks import PowerConfigurationCluster
from zhaquirks.const import (
ALT_DOUBLE_PRESS,
ALT_SHORT_PRESS,
ARGS,
BUTTON,
COMMAND,
COMMAND_OFF,
COMMAND_TOGGLE,
DEVICE_TYPE,
DOUBLE_PRESS,
ENDPOINT_ID,
ENDPOINTS,
INPUT_CLUSTERS,
LEFT,
LONG_PRESS,
MODELS_INFO,
OUTPUT_CLUSTERS,
PROFILE_ID,
RIGHT,
SHORT_PRESS,
TRIPLE_PRESS,
from zhaquirks.xiaomi import (
LUMI,
BasicCluster,
XiaomiAqaraE1Cluster,
XiaomiCustomDevice,
from zhaquirks.xiaomi.aqara.opple_remote import (
COMMAND_1_DOUBLE,
COMMAND_1_HOLD,
COMMAND_1_SINGLE,
COMMAND_1_TRIPLE,
COMMAND_2_DOUBLE,
COMMAND_2_HOLD,
COMMAND_2_SINGLE,
COMMAND_2_TRIPLE,
COMMAND_3_DOUBLE,
COMMAND_3_HOLD,
COMMAND_3_SINGLE,
COMMAND_3_TRIPLE,
MultistateInputCluster,
BOTH_BUTTONS = “both_buttons”
class AqaraRemoteManuSpecificCluster(XiaomiAqaraE1Cluster):
“”“Aqara manufacturer specific settings.”“”
ep_attribute = "aqara_cluster"
# manufacture override code: 4447 (0x115f)
# to get/set these attributes, you might need to click the button 5 times
# quickly.
attributes = XiaomiAqaraE1Cluster.attributes.copy()
attributes.update(
        # operation_mode:
        # 0 means "command" mode.
        # 1 means "event" mode.
        0x0009: ("operation_mode", t.uint8_t, True),
        # click_mode:
        # 1 means single click mode, which is low latency (50ms) but only sends
        #   single click events.
        # 2 means multiple click mode, which has a slightly higher latency but
        #   supports single/double/triple click and long press.
        # default value after factory reset: 1.
        0x0125: ("click_mode", t.uint8_t, True),
class PowerConfigurationClusterH1Remote(PowerConfigurationCluster):
# Aqara H1 wireless remote uses one CR2450 battery.
# Values are copied from zigbee-herdsman-converters.
MIN_VOLTS = 2.5
MAX_VOLTS = 3.0
class RemoteH1SingleRocker(XiaomiCustomDevice):
“”“Aqara H1 Wireless Remote Single Rocker Version WRS-R01.”“”
signature = {
    MODELS_INFO: [(LUMI, "lumi.remote.b18ac1")],
    ENDPOINTS: {
        # SizePrefixedSimpleDescriptor(
        #   endpoint=1, profile=260, device_type=259, device_version=1,
        #   input_clusters=[0, 3, 1], output_clusters=[3, 6])
        1: {
            PROFILE_ID: zha.PROFILE_ID,
            DEVICE_TYPE: zha.DeviceType.ON_OFF_LIGHT_SWITCH,
            INPUT_CLUSTERS: [
                Basic.cluster_id,
                PowerConfiguration.cluster_id,
                Identify.cluster_id,
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
replacement = {
    ENDPOINTS: {
        1: {
            INPUT_CLUSTERS: [
                BasicCluster,
                PowerConfigurationClusterH1Remote,
                AqaraRemoteManuSpecificCluster,
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
device_automation_triggers = {
    # triggers when operation_mode == event
    # the button doesn't send an release event after hold
    (SHORT_PRESS, BUTTON): {COMMAND: COMMAND_1_SINGLE},
    (DOUBLE_PRESS, BUTTON): {COMMAND: COMMAND_1_DOUBLE},
    (TRIPLE_PRESS, BUTTON): {COMMAND: COMMAND_1_TRIPLE},
    (LONG_PRESS, BUTTON): {COMMAND: COMMAND_1_HOLD},
    # triggers when operation_mode == command
    (ALT_SHORT_PRESS, BUTTON): {COMMAND: COMMAND_TOGGLE, ENDPOINT_ID: 1, ARGS: []},
    (ALT_DOUBLE_PRESS, BUTTON): {COMMAND: COMMAND_OFF, ENDPOINT_ID: 1, ARGS: []},
class RemoteH1DoubleRocker1(XiaomiCustomDevice):
“”“Aqara H1 Wireless Remote Double Rocker Version WRS-R02, variant 1.”“”
signature = {
    MODELS_INFO: [(LUMI, "lumi.remote.b28ac1")],
    ENDPOINTS: {
        1: {
            INPUT_CLUSTERS: [
                Basic.cluster_id,
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
        3: {
            #   endpoint=3, profile=260, device_type=259, device_version=1,
            #   input_clusters=[3], output_clusters=[6])
            INPUT_CLUSTERS: [Identify.cluster_id],
            OUTPUT_CLUSTERS: [OnOff.cluster_id],
replacement = {
    ENDPOINTS: {
        1: {
            INPUT_CLUSTERS: [
                BasicCluster,
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
        2: {
            INPUT_CLUSTERS: [
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
        3: {
            INPUT_CLUSTERS: [
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
    (SHORT_PRESS, LEFT): {COMMAND: COMMAND_1_SINGLE},
    (DOUBLE_PRESS, LEFT): {COMMAND: COMMAND_1_DOUBLE},
    (TRIPLE_PRESS, LEFT): {COMMAND: COMMAND_1_TRIPLE},
    (LONG_PRESS, LEFT): {COMMAND: COMMAND_1_HOLD},
    (SHORT_PRESS, RIGHT): {COMMAND: COMMAND_2_SINGLE},
    (DOUBLE_PRESS, RIGHT): {COMMAND: COMMAND_2_DOUBLE},
    (TRIPLE_PRESS, RIGHT): {COMMAND: COMMAND_2_TRIPLE},
    (LONG_PRESS, RIGHT): {COMMAND: COMMAND_2_HOLD},
    (SHORT_PRESS, BOTH_BUTTONS): {COMMAND: COMMAND_3_SINGLE},
    (DOUBLE_PRESS, BOTH_BUTTONS): {COMMAND: COMMAND_3_DOUBLE},
    (TRIPLE_PRESS, BOTH_BUTTONS): {COMMAND: COMMAND_3_TRIPLE},
    (LONG_PRESS, BOTH_BUTTONS): {COMMAND: COMMAND_3_HOLD},
    # known issue: it seems impossible to know which button being pressed
    # when operation_mode == command
class RemoteH1DoubleRocker2(XiaomiCustomDevice):
“”“Aqara H1 Wireless Remote Double Rocker Version WRS-R02, variant 2.”“”
signature = {
    ENDPOINTS: {
        1: {
            # "1": {
            #   "profile_id": 260, "device_type": "0x0103",
            #   "in_clusters": [ "0x0000", "0x0001", "0x0003" ],
            #   "out_clusters": [ "0x0003", "0x0006" ] },
            INPUT_CLUSTERS: [
                Basic.cluster_id,
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
        2: {
            # "2": {
            #   "in_clusters": [ "0x0003" ],
            INPUT_CLUSTERS: [
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
        3: {
            # "3": {
            #   "out_clusters": [ "0x0006" ] } },
replacement = RemoteH1DoubleRocker1.replacement
device_automation_triggers = RemoteH1DoubleRocker1.device_automation_triggers
class RemoteH1DoubleRocker3(XiaomiCustomDevice):
“”“Aqara H1 Wireless Remote Double Rocker Version WRS-R02, variant 3.”“”
signature = {
    ENDPOINTS: {
        1: {
            # "1": {
            #   "profile_id": 260, "device_type": "0x0105",
            #   "in_clusters": ["0x0000", "0x0001", "0x0003"],
            #   "out_clusters": ["0x0003", "0x0006", "0x0008", "0x0300"] }
            DEVICE_TYPE: zha.DeviceType.COLOR_DIMMER_SWITCH,
            INPUT_CLUSTERS: [
                Basic.cluster_id,
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
                LevelControl.cluster_id,
                Color.cluster_id,
        2: {
            # "2": {
            #   "in_clusters": ["0x0003"],
            #   "out_clusters": ["0x0003", "0x0006"] },
            INPUT_CLUSTERS: [
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
        3: {
            # "3": {
            #   "out_clusters": ["0x0006"] },
replacement = {
    ENDPOINTS: {
        1: {
            INPUT_CLUSTERS: [
                BasicCluster,
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
                Color.cluster_id,
        2: {
            INPUT_CLUSTERS: [
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
        3: {
            INPUT_CLUSTERS: [
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
class RemoteH1DoubleRocker4(XiaomiCustomDevice):
“”“Aqara H1 Wireless Remote Double Rocker Version WRS-R02, variant 4.”“”
signature = {
    ENDPOINTS: {
        1: {
            # "1": {
            INPUT_CLUSTERS: [
                Basic.cluster_id,
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
                Color.cluster_id,
        2: {
            # "2": {
            INPUT_CLUSTERS: [
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
        3: {
            # "3": {
        4: {},
        5: {},
        6: {},
replacement = {
    ENDPOINTS: {
        1: {
            INPUT_CLUSTERS: [
                BasicCluster,
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
                Color.cluster_id,
        2: {
            INPUT_CLUSTERS: [
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
        3: {
            INPUT_CLUSTERS: [
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
class RemoteH1DoubleRocker5(XiaomiCustomDevice):
“”“Aqara H1 Wireless Remote Double Rocker Version WRS-R02, variant 5.”“”
signature = {
    MODELS_INFO: [(None, None)],
    ENDPOINTS: {
        1: {
            # "1": {
            #   "in_clusters": [],
            #   "out_clusters": [] }
            INPUT_CLUSTERS: [],
            OUTPUT_CLUSTERS: [],
        2: {
            # "2": {
            #   "out_clusters": [] },
            INPUT_CLUSTERS: [],
        3: {
            # "3": {
            INPUT_CLUSTERS: [],
replacement = {
    ENDPOINTS: {
        1: {
            INPUT_CLUSTERS: [
                BasicCluster,
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
                Color.cluster_id,
        2: {
            INPUT_CLUSTERS: [
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
        3: {
            INPUT_CLUSTERS: [
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
class RemoteH1DoubleRocker6(XiaomiCustomDevice):
“”“Aqara H1 Wireless Remote Double Rocker Version WRS-R02, variant 6.”“”
signature = {
    ENDPOINTS: {
        1: {
            # "1": {
            INPUT_CLUSTERS: [
                Basic.cluster_id,
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
                Color.cluster_id,
        2: {
            # "2": {
            INPUT_CLUSTERS: [
            OUTPUT_CLUSTERS: [
                OnOff.cluster_id,
        3: {
            # "3": {
        4: {
            # "4": {
            #   "in_clusters": ["0x0003", "0x0012"]
            INPUT_CLUSTERS: [Identify.cluster_id, MultistateInput.cluster_id],
        5: {
            # "5": {
        6: {
            # "6": {
