Aqara H2 EU wall switch
You probably have to restart z2m after enabling that. You might also need to press any button in the switch. If it still doesn’t show the entities in HA, then I have no idea
Nice my very basic automation works now after restarting Z2M and MQTT and using your blueprint.
Now on to figure out how to handle the led on the switch itself depending on the status of the lights… Now it’s always blue and never changes.
Hate to be the bearer of bad news, but you can’t do that. See here.
Hey thks for the reply !
Yes I read through that so I gave up quickly. I can still toggle the blue led on/off by toggling the switch itself so it “works” on the top button.
But yes no luck on bottom buttons…
(I will open another thread for figuring out how to loop through hue scenes using the bottom button single click)
In case somebody runs into the same issue.
An update got stuck through the Matter integration. Removing the device and re-adding it, then forcing the update helped push it through.
