Hi everyone. I was trying for several days to trigger leakage sensor with my Aqara hub (fw 3.1.1) to play panic sirene, the problem is that there is no play_ringtone service present that is used by everyone, only 2 objects are inside hub after integration via Homekit controller: light bulb and security system - so no method to call sirene.
I have the same issue. Gateway connected via HomeKit integration. Any solution?
Also I can’t force to turn on the gatewaylight with automation, switching off is working fine.
In fact for me no issue to turn light on or of, but no siren available. The strange thing is that in Aqara Home IOS app this automation works fine with Police sirene 1 ringtone, so it’s definitely the issue with integration method in HA.
Hi guys. I’ve got response from Aqara support that ringtones are not available in HomeKit, so no chance to have them in HA via HomeKit integration. I believe another way is to integrate via Xiaomi integration, but not sure we can get a key as I didn’t succeed to activate developer mode for my model =(
