Aqara Light switch H2 wireless switch
I am using a M3 hub linked via HomeKit integration to home assistant.
I am curious if the Aqara Light Switch H2 that is a child device of the M3 Hub…. Is able to expose its wireless switch to home assistant ?
I believe the M3 hub can function as a Matter bridge, so you may be able to expose its devices to HA by adding the M3 to HA as a Matter device.
If you don’t already have the Matter add-on and its associated Integration (along with IPv6 networking) enabled on HA, take a look at those docs first.
