Hey everyone,
I’m trying to integrate my Aqara M2 Hub into Home Assistant via Matter, but I’m running into an issue. The setup works in general, and I can successfully add the Matter Bridge in Home Assistant. However, only 19 out of my 26 Aqara sensors/devices show up in Home Assistant.
What I’ve Tried So Far:
- Updated Firmware: My Aqara M2 Hub is running the latest firmware.
- Checked Aqara App: All 26 devices are visible and working correctly in the Aqara Home app.
- Restarted Home Assistant: No change after multiple reboots.
- Removed & Re-added the Matter Bridge: I reset the Matter pairing in both Aqara Home and Home Assistant, but the issue persists.
- Checked HA Logs: No clear error messages related to the missing devices.
- Matter Device Limit?: I’ve read that some Matter bridges have a limit of 20 devices, but I couldn’t find official confirmation for the Aqara M2 Hub.
Questions:
- Has anyone else experienced this issue with the Aqara M2 Hub?
- Is there a known device limit for Matter bridges in Home Assistant?
- Any workarounds to get all 26 devices to show up?
Thanks in advance for any help!
