Aqara Magic Cube + Deconz, automation triggered on Wake-up
Hi everyone, I connected the Aqara Magic Cube to Deconz via the addon in Home Assistant, I wanted to create automations, such as turning on the lights when I turn it 90 degrees, and following a guide I used it as a trigger (in the guided creation of HA automations) Device -> Mi Magic Cube (the name of the device) -> Device rotated 90 degrees.
Everything is ok here, but when the cube is inactive for a few minutes the cube sends a “Wake-up” signal with event id 7000 on deconz_event and triggers the automation to switch on the lights, just by touching it! I don’t understand how it’s possible because I haven’t touched anything but it does it with any type of movement, even 180 degrees or moving, any ideas? It’s a deconz problem>
Hi ! I’m having the same issue with my cube, that sends random events when waking up… Did you fix yours ?
hello, sorry for the delay, my problem has been solved with a bugfix in version 105.2 (or 105.3, I don’t remember)
