Aqara motion sensor became unavailable
Configuration as below, just installed a new Aqara motion sensor, works ok for a few hours and then get ‘became unavailable’ . I have to delete and reconnect the device and then get the same thing again. I have no problems with Tradfri motion sensors. Controller is Phoscon RaspBee II , also, I see it in visualisation but no connection either via controller or ikea light router
Are there any logs that may help me ?
lumi.sensor_motion.aq2
by LUMI
IEEE: 00:15:8d:00:07:d4:9f:14
Nwk: 0x9173
Device Type: EndDevice
LQI: Unknown
RSSI: Unknown
Last Seen: 2022-09-30T23:58:55
Power Source: Battery or Unknown
Quirk: zhaquirks.xiaomi.aqara.motion_aq2.MotionAQ2
Controller
deCONZ = dresden elektronik deCONZ protocol: RaspBee II
by ZHA
Zigbee info
IEEE: 00:21:2e:ff:ff:08:b6:25
Nwk: 0x0000
Device Type: Coordinator
LQI: Unknown
RSSI: Unknown
Last Seen: 2022-10-01T10:53:50
Power Source: Mains
I’ll second this issue. I just got one of these to try out and am having the same behavior. Did you ever resolve this?
edit: found this so that is likely the issue: Xiaomi & Aqara Devices - Pairing & Keeping them connected - Devices - Hubitat
Seems to stll be the case in Jan’25 …
I will swap to a different motion detection device as it is anoying to only get 24hrs active use between each remove-reinstall.
Yeah I’m also experiencing this issue. I have two HA installs at two venues, each one has the motion sensor connected. Works flawlessly in one of the venues. At the other place it works for a few hours and then becomes unavailable
