I don’t know how to make this work, I even don’t need LUX value, I only need to have a trigger when there is a motion.
This is how I setup in Home Assistant
above: 0
below: 1000
device_id: 5dc862c8f6964b699ad303fc087d4974
domain: sensor
entity_id: sensor.living_motion_sensor
for:
hours: 0
minutes: 0
seconds: 0
platform: device
type: illuminance
entity_id: light.master_light
service: light.toggle
I changed value of Above, Below, For, but even when LUX changed the value, it’s not working
I also tried with State but doesn’t work neither
platform: state
to: 'on'
There are two entities for this motion only
sensor.living_motion_sensor_battery_level
There is no Binary Sensor value.
I even don’t care about LUX value, I just want to be triggered when there’s a motion.
There is no event even I moved in front of the sensor
This is LUX value
nickrout
(Nick Rout)
July 31, 2020, 6:46am
2
A motion sensor only has two values, true/false,1/0, detected/clear or whatever. There is no need to measure over or under 1000.
Yeah but I can’t find any entities for this value.
There are only two entities for Device
entity_id: sensor.living_motion_sensor_battery_level
I also tried with State but can’t make it work
platform: state
to: 'on'
Do I do a wrong setup in Deconz?
nickrout
(Nick Rout)
July 31, 2020, 7:20am
4
I haven’t set it up with deconz, only with the xiaomi gateway and with zigbee2mqtt (z2m)
With z2m I get four entites:
occupancy, link quality, battery and illuminance, named
binary_sensor.motion_1_occupancy sensor.motion_1_linkquality sensor.motion_1_battery sensor.motion_1_illuminance
Going into the dev tools/states are you sure you don’t have a binary_sensor
Hi nickrout,
I go to Developer Tools, search for all Motion Sensor entities for this device
Looks like there are only 2?
I also searched for binary_sensor
This is the only one
nickrout
(Nick Rout)
July 31, 2020, 9:03am
7
Looks like a deconz error then - whether in deconz itself, or in your use of it I am not sure.
Does deconz’s documentation or forum say anything about this sensor?
nickrout
(Nick Rout)
July 31, 2020, 9:07am
8
This suggests it should work https://www.home-assistant.io/integrations/deconz/#verified-supported-binary-sensors
Although there are many versions of xiaomi hardware. It is hard to tell from a simple device name what model you are dealing with.
Hi nickrount,
I re-paired the device and it’s now working properly. I have inary_sensor.presence_4
Thank you
