Hi every one!
I tried anything to make my aqara motion sensor back to work, but nothing until now.
A year ago It completly works on zigbee2mqtt on cc2531. But in the last months one per time stop working and not repairing any more even trying backups of HA when they works.
When I delete the sensor and try to repair It just not appear any more like there is no battery.
I changed 2 times the batteries and nothing too.
Cc2531 is update to the last firmware 20211116. Rasp3.
The same on ZHA and nothing, only the other aqara sensors like temperature and door open works normal.
Testing they in Aqara Hub everething os fine, just on HA persist the problem.
Anyone knows How can I do to make this works again?
I am having the same issue now with couple of aqara motion sensors, did you find out what the issue was?
Does one of you been able to resolve this issue ?
I have the same, I switched from Xiaomi Gateway to Sonoff stick + zigbee2mqtt + mosquitto, I’m able to pair my motion sensor correctly but it stops sending any data to zigbee2mqtt after few seconds after the pairing.
I have an aqara temperature sensor too, and this one works perfectly.
