i am using aqara switches 1,2 and 3 gang, the 1 and 2 gang usually appears as switches, but the 3 gang appears as light (which is my case is wrong, as i connect fans and other).
i am using conbee 2 and ZHA, i correct the device type in the configuration.yaml as below:
zha:
device_config:
54:ef:44:10:00:0c:0d:bc-1:
type: "switch"
54:ef:44:10:00:0c:0d:bc-2:
type: "switch"
54:ef:44:10:00:0c:0d:bc-3:
type: "switch"
anyhow, prior to 2.5.1, this switch would work just fine, now, only endpoint 1 is working the other two are not responsive.
btw… if i keep them as light, they work normally
what would have gone wrong?
