Aqara T2 Dual Relay issue
Been fixing Zigbee2MQTT settings and noticed that lumi.switch.acn047 aka Aqara T2 Dual Relay is publishing its status every 13 seconds.
this does not seem to be normal, most Zigbee device in network publish status like every 20 minutes when there is nothing to report.
Any idea whats going on? Thanks
Once every 13s doesn’t sound too bad for a device which reports power consumption. Any slower than that and it might miss power readings.
I assumed that power reading and reporting/publishing are two separate events, while most other ZB devices i have report change of state - temp, humidity, switch pressed etc.
In most of time when power switches are off, it would report all the time without any change in state.
Even when considering it as a power outage report, … i guess it might be useful if HA is using only zigbee devices lets say without UPS.
