Aqara T2 E26 bulbs are "not supported"
Running HAOS (2025.2.4) with Z2M (2.1.1) using SLZB-06P7 in Zigbee coordinator mode(zStack3). things are working fine with other bulbs.
I just rec’d and installed these Aqara T2 E26 (LB-L01E). Changed the protocol to Zigbee, and Z2M finds them and I’m able to toggle off/on/dim but Z2M status is: Not Supported?
has NE1 got this error fixed? I tried the external_converters but I don’t have a clear understanding on how or where to place the code from Dev console tab in Z2M.
any help or links would be greatly appricated…Thanks!
Someone has already raised an issue on the Z2M github. Support should be coming soon, probably as early as next month if someone submits a PR with the working converter in time for the next release.
Here, read this
thats good news about the issues already being looked at…thanks for that info.
