Aqara T2 for curtain/shutter
I would like to automate my new window shutter with the aqara T2 relay.
When you use it with the aqara hub, you can set it to shutter mode which interlocks the relays so both cannot be active at the same time.
in Homeassist I cannot find any of this.
Should I just define this in the automation?
Is this enough so the magic smoke doesn’t come out?
thanks
I’m guessing you’re using the native HomeAssistant zigbee integration called ZHA. If that’s the case, I don’t believe this has been implemented yet.
You might want to consider moving to Zigbee2MQTT instead of attempting to let out the magic smoke. It has built-in support for interlock on the T2 relay.
Ah, ok. Yes I seem to be using ZHA.
Since the aqara was borrowed only, i switched to the MOES curtain module instead (which isn’t without any problems either - separate thread)
I found a solution for the interlock.
But this still leaves shutter positioning.
