lucianv
(Lucian)
October 10, 2021, 8:04am
21
I reinstalled it and leave default config in supervisor tab
logins: []
customize:
active: false
folder: mosquitto
certfile: fullchain.pem
keyfile: privkey.pem
require_certificate: false
Then I changed zigbee2mqtt as well and removed user/pass
homeassistant: true
permit_join: true
mqtt:
base_topic: homeassistant
server: mqtt://192.168.55.10:1883
serial:
port: /dev/ttyACM0
devices:
'0x00158d000465705c':
friendly_name: temp-living
'0x00158d00067cf4f8':
friendly_name: temp-dining
'0x00158d00067d99bd':
friendly_name: temp-bucatarie
'0x00158d00067bed0d':
friendly_name: temp-baie-parter
'0x00158d0001d72a39':
friendly_name: temp-baie-luca
'0x00158d00033de11b':
friendly_name: temp-dormitor-luca
'0x00158d00057f9436':
friendly_name: temp-hol-etaj
'0x00158d000411a1e0':
friendly_name: temp-dormitor-noi
'0x00158d0001d7658c':
friendly_name: temp-dressing-etaj
'0x00158d000588a12a':
friendly_name: temp-baie-noi
'0x00158d0006795415':
friendly_name: temp-dormitor-mijloc
Then I see a notification for new devices and saw in integration mosquitto broker and added it
I removed user/pass from here also
Image mq hosted in ImgBB
So now I am waiting to HA discover the zigbee2mqtt devices
Are these correct steps?
francisp
(Francis)
October 10, 2021, 8:06am
22
Not quit. The latest mqtt add-on does not support anonymous connections. User/Password are always needed.
lucianv
(Lucian)
October 10, 2021, 8:17am
23
Ok, Added in mqtt conf in supervisor user /pass
logins:
- username: mqtthass
password: '12345678'
customize:
active: false
folder: mosquitto
saved and restarted
then go to configuration → Integrations and added user pass here also on mqtt
Then changed conf on the pi as well
homeassistant: true
permit_join: true
mqtt:
username: 'mqtthass'
serial:
port: /dev/ttyACM0
devices:
and restarted zigbee2mqtt as well
lucianv
(Lucian)
October 10, 2021, 11:12am
24
Still waiting for devices to appear again but nothing happened yet…is there any way to configure them manually?
First time when I installed it they show up under configuration / integrations mqtt but now is still empty
francisp
(Francis)
October 10, 2021, 11:53am
25
Strange problem. How is Zigbee2MQTT installed ?
lucianv
(Lucian)
October 10, 2021, 12:05pm
26
Followed this tutorial and using a raspi 4 and a CC26X2R1 card.
I am thinking to move the CC26X2R1 card directly in intel nuc where HA is running and install zigbee2mqtt addon …
L.E. sorry missed the link
francisp
(Francis)
October 10, 2021, 12:10pm
29
Ok, an installation on bare metal. Probably Raspbian if on pi4.
Try :
apt-get update && apt-get upgrade -y
and then
apt-get install mosquitto
to install mosquitto on your Pi 4
then configure HA to access the mqtt on your Pi4
lucianv
(Lucian)
October 10, 2021, 12:14pm
30
You mean to configure mqtt broker on the pi and not on the HA
lucianv
(Lucian)
October 11, 2021, 11:25am
32
Meanwhile I moved CC26X2R1 card on the nuc and installed zigbee2mqttaddon…seems till now is working. If that will be fine, then I will move the nuc in the place of pi in order to have all xiaomi sensors in range…one point of failure less
Will keep you posted anyway
Thanks a lot for all you help, really appreciated
I had a similar issue and found the credentials in the MQTT broker were not what I had set when setting up Mosquito.
Setting>core-mosquitto MQTT?Configure>Re-configure MQTT> Enter the MOsquito Username and password you set up initially.
Worked for me !
