I have 3 of these Aqara TVOC sensors. 2 of 3 of these are reporting is way too often.
These are not supposed to report unless the change is significant enough and most are complaining that they’re reporting too infrequently. My issue is quite the opposite:
MQTT updates for Aqara TVOC in Living room:
Zigbee2MQTT:info 2023-05-06 10:32:20: MQTT publish: topic 'zigbee2mqtt/Aqara Living room', payload '{"battery":100,"device_temperature":21,"display_unit":"ppb_celsius","humidity":60.2,"linkquality":229,"power_outage_count":33,"temperature":22.1,"update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voc":33,"voltage":3010}'
Zigbee2MQTT:info 2023-05-06 10:32:30: MQTT publish: topic 'zigbee2mqtt/Aqara Living room', payload '{"battery":100,"device_temperature":21,"display_unit":"ppb_celsius","humidity":59.1,"linkquality":225,"power_outage_count":33,"temperature":22.1,"update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voc":33,"voltage":3010}'
Zigbee2MQTT:info 2023-05-06 10:35:00: MQTT publish: topic 'zigbee2mqtt/Aqara Living room', payload '{"battery":100,"device_temperature":21,"display_unit":"ppb_celsius","humidity":60.3,"linkquality":225,"power_outage_count":33,"temperature":22.1,"update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voc":33,"voltage":3010}'
Zigbee2MQTT:info 2023-05-06 10:35:10: MQTT publish: topic 'zigbee2mqtt/Aqara Living room', payload '{"battery":100,"device_temperature":21,"display_unit":"ppb_celsius","humidity":58.7,"linkquality":225,"power_outage_count":33,"temperature":22.1,"update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voc":33,"voltage":3010}'
Zigbee2MQTT:info 2023-05-06 10:35:20: MQTT publish: topic 'zigbee2mqtt/Aqara Living room', payload '{"battery":100,"device_temperature":21,"display_unit":"ppb_celsius","humidity":59.9,"linkquality":222,"power_outage_count":33,"temperature":22.1,"update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voc":33,"voltage":3010}'
Zigbee2MQTT:info 2023-05-06 10:35:40: MQTT publish: topic 'zigbee2mqtt/Aqara Living room', payload '{"battery":100,"device_temperature":21,"display_unit":"ppb_celsius","humidity":58.8,"linkquality":225,"power_outage_count":33,"temperature":22.1,"update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voc":33,"voltage":3010}'
In this example, the humidity is fluctuating all over the place.
This results in these graphs in Home Assistant:
and in Grafana:
Zigbee2MQTT Reporting:
Zigbee2MQTT Settings (Specific):
Note: 1 of 3 Aqara TVOC devices that does not spam reports:
1 of 3 the Aqara TVOC devices has no Reporting set in Zigbee2MQTT. I don’t understand why/how, I did not delete it. It does not have the usual/normal 3 lines for (Humidity, Temperature, GenAnalogInput as shown 2 screenshots above.
BUT this is the only 1 of 3 Aqara sensors that is reporting the humidity correctly (that is why I think the reporting frequency is set too high for the others?)
Bedroom Zigbee2MQTT reporting tab empty:
Bedroom MQTT message / Grafana graph clean:
About my setup:
- Tubeszb’s cc2652p2-ethusb coordinator
- Mosquitto → Zigbee2MQTT → danrue-ser2net1 running in Docker on Synology NAS
- Home Assistant 2023.5.2
Supervisor 2023.04.1
Operating System 10.1
Frontend 20230503.3 - latest
I have tried:
- Changing ‘Min rep interval’ in Zigbee2MQTT from 10 seconds to 60 → always got a failed error message
- Reconfiguring the Aqara TVOC devices via Zigbee2MQTT → always got a failed error message
- Restarting / repairing the Aqara TVOC devices, restarting cc2652p2 coordinator, moquitto, Zigbee2MQTT and the entire system
- Removing the Aqara TVOC devices via Zigbee2MQTT → always got a failed error message
- Taking battery out of the Aqara TVOC devices for 10+ minutes and then trying to connect again
- Searching the internet for possible solutions for 2 weeks
Nothing seems to work.
Any suggestions would be hugely appreciated! Many thanks in advance.
