I have the U100 lock installed and want to create an automation to turn off the house alarm upon lock opening with a fingerprint. I did this on my front door using a U50 lock and a Ubiquiti G4 doorbell fingerprint scanner. However, I can't seem to find what the U100 lock outputs when an authenticated fingerprint is scanned and the lock is unlocked. All I can find is the "unlocked" output. So, does the U100 put out anything for a successful fingerprint scan?
Try in the Aqara app under Profile / Connect to Ecosystems / Signal management. Then export Matter signals. These then come up in Home Assistant.
