Aqara U200 Matter Lock Manager not working
Hey folks,
I paired my Aqara U200 to a Home Assistant Connect ZBT-1 and it works via Matter.
Recently Matter Lock Manager was added:
However, that does not seem to work for me.
Is this not supported on the lock, even though I can manage PINs and people via the GUI?
Hi, it works for me with my aqara u200, but only full access pin and I have to restart the matter server to make the pin work.
Thank you for the tip. I will try that tomorrow!
It dosen't work for me at all (Aqara U200). On the device page Matter lock, the Manage lock option opens a dialog where there is no users although I have 4 configured before, I can add new ones, but no edit existing ones, or remove them.
I played a bit with it and it seems, there are two different sets of users. To me it looks like I have a set of users for the Aqara Home App and a set for Home Assistant / Matter. If I look at Aqara I only see those users, If I look in Home Assistant I only see the others.
I have no Aqara Matter Hub and therefore no Matter connection for the Aqara App.
Not what I expected or hoped for, but at least I can setup temporary users with HA.
Would be nice to get the user management unified in the future.
Yes, it seems to work as you say, but there should be a single user management system, not two. Also, the users you define in HA can only work with the PIN and not with the fingerprint. Hopefully this will be fixed in the future...
This is how it works for me:
I can only create a full access user. That works also immediately.
I do not have an Aqara Hub or anything.
Just Home Assistant ZBT-1.
