I've had two of these switches for a couple of years now, and it seems like my basic automation to turn off certain lights with a single press has started to fail.
Basically, about a month+, I have to go into the Zigbee2MQTT add-on to remove and pair them again. After a while, pressing any sequence of buttons yields no response at all.
My question is, am I the only one experiencing this issue with Zigbee2MQTT and the Aquara WXKG11LM?
Since Xiaomi devices do not fully comply to the Zigbee standard, it sometimes happens that they disconnect from the network. Most of the times this happens because of the following reasons:
Device has a weak signal, you can see the signal quality in the published messages as linkquality. A linkquality < 20 is considered weak.
Low battery voltage, this can even happen when the battery still appears full. Try a different battery.
Thanks for taking the time to reply!
My linkquality is 212lqi and I have few router switches around them.
I guess I will try to replace the bettery although it shows 100%.
I have install Zigbee Mqtt and Have tried to use zegbee buttons in my automations with no luck. I have try with the sonoffo, aquaria wireless mini switch and Samsung. I can not get the buttons to work. Im lost and far from being a code guy. These all work in Zha and not interesting in leave zigbeeMQtt. Any help would be amazing at this point …
