I have an issue when discovery zigbee AQSZB-110 Air quality monitor manufactory by Develco Products A/S, it don’t show the value for airqualityppb
when i check the value return by the deconz api show the follow parameter:
"config": {
"battery": 100,
"on": true,
"reachable": true
"ep": 38,
"etag": "7a4cc5e3ce21be0f2a8db15cc336e4bd",
"lastannounced": "2021-09-13T18:07:22Z",
"lastseen": "2021-09-13T19:17Z",
"manufacturername": "Develco Products A/S",
"modelid": "AQSZB-110",
"name": "AirQuality 41",
"state": {
"airquality": "good",
"airqualityppb": 161,
"lastupdated": "2021-09-13T19:17:54.921"
"type": "ZHAAirQuality",
"uniqueid": "00:15:bc:00:36:00:0c:7c-26-fc03"
when iit is discover in HomeAssisten only display the sensor for state of airquality not display airqualityppb, capture below.
on homeassisten log file i saw also show the value:
yesterday at 20:36:14 '40': {'config': {'battery': 100,
yesterday at 20:36:14 'offset': 0,
yesterday at 20:36:14 'on': True,
yesterday at 20:36:14 'reachable': True},
yesterday at 20:36:14 'ep': 38,
yesterday at 20:36:14 'etag': 'c953ab76c6b073bb1b3750b180bdadf1',
yesterday at 20:36:14 'lastannounced': '2021-09-13T18:07:22Z',
yesterday at 20:36:14 'lastseen': '2021-09-13T18:33Z',
yesterday at 20:36:14 'manufacturername': 'Develco Products A/S',
yesterday at 20:36:14 'modelid': 'AQSZB-110',
yesterday at 20:36:14 'name': 'Humidity 40',
yesterday at 20:36:14 'state': {'humidity': 4640,
yesterday at 20:36:14 'lastupdated': '2021-09-13T18:33:51.774'},
yesterday at 20:36:14 'type': 'ZHAHumidity',
yesterday at 20:36:14 'uniqueid': '00:15:bc:00:36:00:0c:7c-26-0405'},
yesterday at 20:36:14 '41': {'config': {'battery': 100, 'on': True, 'reachable': True},
yesterday at 20:36:14 'etag': '1458ea648f534cef64b7d96769ac497e',
yesterday at 20:36:14 'name': 'AirQuality 41',
yesterday at 20:36:14 'state': {'airquality': 'good',
yesterday at 20:36:14 'airqualityppb': 208,
yesterday at 20:36:14 'lastupdated': '2021-09-13T18:33:21.759'},
yesterday at 20:36:14 'type': 'ZHAAirQuality',
yesterday at 20:36:14 'uniqueid': '00:15:bc:00:36:00:0c:7c-26-fc03'},
and then some aditional logs
yesterday at 20:51:22 2021-09-13 20:51:22 DEBUG (MainThread) [pydeconz.websocket] {"attr":{"id":"39","lastannounced":"2021-09-13T18:07:22Z","lastseen":"2021-09-13T18:51Z","manufacturername":"Develco Products A/S","modelid":"AQSZB-110","name":"Air quality sensor","swversion":null,"type":"ZHATemperature","uniqueid":"00:15:bc:00:36:00:0c:7c-26-0402"},"e":"changed","id":"39","r":"sensors","t":"event","uniqueid":"00:15:bc:00:36:00:0c:7c-26-0402"}
yesterday at 20:51:22 2021-09-13 20:51:22 DEBUG (MainThread) [pydeconz.websocket] {"attr":{"id":"40","lastannounced":"2021-09-13T18:07:22Z","lastseen":"2021-09-13T18:51Z","manufacturername":"Develco Products A/S","modelid":"AQSZB-110","name":"Humidity 40","swversion":null,"type":"ZHAHumidity","uniqueid":"00:15:bc:00:36:00:0c:7c-26-0405"},"e":"changed","id":"40","r":"sensors","t":"event","uniqueid":"00:15:bc:00:36:00:0c:7c-26-0405"}
yesterday at 20:51:22 2021-09-13 20:51:22 DEBUG (MainThread) [pydeconz.websocket] {"attr":{"id":"41","lastannounced":"2021-09-13T18:07:22Z","lastseen":"2021-09-13T18:51Z","manufacturername":"Develco Products A/S","modelid":"AQSZB-110","name":"AirQuality 41","swversion":null,"type":"ZHAAirQuality","uniqueid":"00:15:bc:00:36:00:0c:7c-26-fc03"},"e":"changed","id":"41","r":"sensors","t":"event","uniqueid":"00:15:bc:00:36:00:0c:7c-26-fc03"}
yesterday at 20:52:23 2021-09-13 20:52:23 DEBUG (MainThread) [pydeconz.websocket] {"attr":{"id":"39","lastannounced":"2021-09-13T18:07:22Z","lastseen":"2021-09-13T18:52Z","manufacturername":"Develco Products A/S","modelid":"AQSZB-110","name":"Air quality sensor","swversion":null,"type":"ZHATemperature","uniqueid":"00:15:bc:00:36:00:0c:7c-26-0402"},"e":"changed","id":"39","r":"sensors","t":"event","uniqueid":"00:15:bc:00:36:00:0c:7c-26-0402"}
yesterday at 20:53:52 2021-09-13 20:53:52 DEBUG (MainThread) [pydeconz.websocket] {"attr":{"id":"39","lastannounced":"2021-09-13T18:07:22Z","lastseen":"2021-09-13T18:53Z","manufacturername":"Develco Products A/S","modelid":"AQSZB-110","name":"Air quality sensor","swversion":null,"type":"ZHATemperature","uniqueid":"00:15:bc:00:36:00:0c:7c-26-0402"},"e":"changed","id":"39","r":"sensors","t":"event","uniqueid":"00:15:bc:00:36:00:0c:7c-26-0402"}
yesterday at 20:53:52 2021-09-13 20:53:52 DEBUG (MainThread) [pydeconz.websocket] {"attr":{"id":"40","lastannounced":"2021-09-13T18:07:22Z","lastseen":"2021-09-13T18:53Z","manufacturername":"Develco Products A/S","modelid":"AQSZB-110","name":"Humidity 40","swversion":null,"type":"ZHAHumidity","uniqueid":"00:15:bc:00:36:00:0c:7c-26-0405"},"e":"changed","id":"40","r":"sensors","t":"event","uniqueid":"00:15:bc:00:36:00:0c:7c-26-0405"}
yesterday at 20:53:52 2021-09-13 20:53:52 DEBUG (MainThread) [pydeconz.websocket] {"attr":{"id":"41","lastannounced":"2021-09-13T18:07:22Z","lastseen":"2021-09-13T18:53Z","manufacturername":"Develco Products A/S","modelid":"AQSZB-110","name":"AirQuality 41","swversion":null,"type":"ZHAAirQuality","uniqueid":"00:15:bc:00:36:00:0c:7c-26-fc03"},"e":"changed","id":"41","r":"sensors","t":"event","uniqueid":"00:15:bc:00:36:00:0c:7c-26-fc03"}
HomeAssistante version : core-2021.10.0.dev20210902
any idea what could be wrong or it’s not supported ?
