Aquara window sensor not updating
Hi , hope everyone is well and enjoying the uks nice weather…
I’ve just purchased 3 of the Aqara window/door sensors. They are nice and small and added to HA very easily.
But now I have a problem… they are not updating in HA. They show as closed even when open (yes checked the magnets are close enough)
I also noticed in the Zigbee settings it states power outages at 27 when it’s a battery powered device .
So confused as to why it’s not updating and why Zigbee is saying power outages for a battery device.
As anyone used these devices ? Any ideas what I might need to do.
Zigbee is via MQTT by the way with a network co-ordination.
Thank you
Andy
Yes.
First things first: It’s Aqara, not AqUara. If you fix the spelling, people searching for issues with these devices are more likely to find your thread.
Secondly: your issues are almost certainly because you have interference or not enough routers. Read this to understand how zigbee works, and why end-devices like your window sensors require zigbee routers if they’re too far away from your coordinator.
Third: check the batteries on those things. Even if they’re “new”, they could have been sitting on a shelf for a couple of years. The power outage reporting 27 could be an indication of either a failing battery or the issues I mentioned in point 2 above.
Sorry if my one spelling mistake offends.
The sensor in question has a link quality of 255 as it’s less than a metre from a repeater.
quick update hopefully without any spelling mistakes.
I reset the sensor and this time it appears to have fixed the issue.
Not sure why this occurred but its fixed.
The spelling advice was only to ensure your question/issue would get maximum exposure.
There are so many threads added daily so honestly spelling matters!
