All,
I am planning my pool and as I am a HA user, of course I was looking which Salt System I could use to have a good implementation into HA. Here in Germany, I can not find user experiences with the Aquark Mr. Pure MPS22. May I ask you guys before I buy? Do you have good experience with the unit? I am planning for a 25 qubicmeter pool which is 25.000 Liter, which is 6600 gallons. Does the Mr. Pure work good? Would be a MPS22 really enough for this size of pool as described by the manufacturer and would you recommend the system?
Exactly, msp14 is enough for you, my experience so far is very good, I’m already in my second season, you always need to calibrate the probes at the beginning of the season, calibration is a separate chapter, you need to follow certain procedures and it goes like clockwork. There is also good support via chat on the aquark website
Just got my kit to work.
Got exactly what was on this thread:
• M8 3-pin (male) connector
• M5Stack ATOM Lite ESP32 Development Board with Wi-Fi Programmable Kit
• M5Stack ATOM Tail485 TTL to RS485 communication module (Level conversion serial port)
My Mr Pure Manual (Version 3, December 2024), RS485 PINOUT:
PIN1 - 485-A
PIN3 - 485-GND
PIN4 - 485-N
Cant thank enough @maros22 for putting this together! It’s truly a rest to have all that info in Home Assistant!
Hi Maros,
Thanks for all the good work.
I will be installing one of these very soon.
I see you are also controlling a INVERPRO filter pump.
I will be using one of those too. How did you integrated it on HA? Also MODBUS? Do you have a adress table?
Also I am thinking of using a W32-eth0 module plus a rs485 ttl converter. Any advise for the rs485 adapter board I should use?
Thanks in advance.
Great work, mine is working perfectly, just had to adjust:
- platform: modbus_controller
modbus_controller_id: mrpure
name: "Electrical conductivity"
register_type: read
address: 0x0002
skip_updates: 2
value_type: U_WORD
unit_of_measurement: "ppm"
filters:
- multiply: 0.5
in the app the value was reading half of what ESP was outputting, this filter, fixes it.
Cheers
esphome:
friendly_name: Inverpro
esp32:
board: m5stack-atom
framework:
type: arduino
# Enable logging
logger:
baud_rate: 0
level: VERY_VERBOSE
hardware_uart: UART0
# Enable Home Assistant API
api:
encryption:
key: "xxxx"
ota:
- platform: esphome
password: "xxxxxxx"
wifi:
ssid: !secret wifi3_ssid
password: !secret wifi3_password
manual_ip:
static_ip: 192.168.5.68
gateway: 192.168.5.2
subnet: 255.255.255.0
ap:
ssid: "Inverpro Fallback Hotspot"
password: "xxxxx"
captive_portal:
web_server:
port: 80
uart:
rx_pin: 32
tx_pin: 26
baud_rate: 9600
modbus:
# flow_control_pin: GPIO4
send_wait_time: 300ms
modbus_controller:
- id: inverpro
## the Modbus device addr
address: 170
modbus_id: modbus1
update_interval: 8s
number:
modbus_controller_id: inverpro
address: 3001
use_write_multiple: true
unit_of_measurement: "%"
value_type: U_WORD
min_value: 0
max_value: 130
step: 5
mode: slider
device_class: power
address: 2003
register_type: holding
value_type: U_WORD
address: 2004
value_type: U_WORD
filters:
- lambda: return x /10;
- platform: wifi_signal
name: "WiFi signál Inverpro"
update_interval: 60s
switch:
icon: "mdi:toggle-switch"
optimistic: true
turn_on_action:
- number.set:
value: 70
turn_off_action:
- number.set:
value: 0
button:
name: "Pump Normal Mode"
icon: "mdi:speedometer-slow"
on_press:
- number.set:
value: 70
name: "Pump Boost Mode"
icon: "mdi:speedometer-medium"
on_press:
- number.set:
value: 90
name: "Pump Full Mode"
icon: "mdi:speedometer"
on_press:
- number.set:
value: 120
select:
name: "Pump Power Preset"
optimistic: true
options:
- "Normal"
- "Boost"
- "Full"
initial_option: "Normal"
on_value:
then:
- lambda: |-
if (x == "Normal") {
id(inverpro_power).make_call().set_value(70).perform();
} else if (x == "Boost") {
id(inverpro_power).make_call().set_value(90).perform();
} else if (x == "Full") {
id(inverpro_power).make_call().set_value(120).perform();
text_sensor:
bitmask: 0
address: 2002
raw_encode: HEXBYTES
icon: "mdi:pump"
lambda: |-
uint16_t value = modbus_controller::word_from_hex_str(x, 0);
switch (value) {
case 1: return std::string("ON");
case 0: return std::string("OFF");
default: return std::string("Unknown");
return x;
binary_sensor:
name: "DC voltage Abnormal"
icon: "mdi:check-circle"
address: 2001
bitmask: 0x1
device_class: problem
entity_category: diagnostic
name: "AC current sampling circuit failure"
address: 2001
bitmask: 0x2
name: "Phase-deficient protection"
address: 2001
bitmask: 0x4
name: "Master drive error"
address: 2001
bitmask: 0x8
name: "Heat sink sensor error"
address: 2001
bitmask: 0x16
name: "Heat sink over"
address: 2001
bitmask: 0x32
name: "Output current exceeds limit"
address: 2001
bitmask: 0x64
name: "Input voltage abnormal"
address: 2001
bitmask: 0x128
name: "No water protection"
address: 2001
bitmask: 0x256
name: "Device communication failure"
address: 2001
bitmask: 0x512
name: "EEPROM reading failure"
address: 2001
bitmask: 0x1024
name: "RTC time reading Error"
address: 2001
bitmask: 0x2048
name: "Master board EEPROM"
address: 2001
bitmask: 0x4096
name: "Motor current detection Error"
address: 2001
bitmask: 0x8192
name: "Motor power overload"
address: 2001
bitmask: 0x16384
name: "PFC protection"
address: 2001
bitmask: 0x32768
Anyone tried Tuya Local? Is it working? I’m considering buying it, but want to use the integrated WiFi and I’m using Tuya Local anyway for other automations.
Hey,
These devices are advertised as using inverter technology.
I asked a dealer whether the power output is controlled via PWM or via current. The answer was that it’s controlled via current. Has anyone actually measured this?
Best
Hi maross22,
i am planing to buy MPS14 Premium and i wanna controll from HA. If I understand, I must buy connector and two device what you wrote and only cinnect to MPS14 with coonector and setup esphome? Thanks for help
Correct, i just did the same, works fine. I did have to switch the cables around a bit to the the RS485 connection going.
Hi, has anyone actually tried using TUAY Smartlife or similar apps that are already integrated into HM? Does anyone here happen to use them?
Thanks for your help
Hi, do you know if it will also be compatible with the MPP10 series, specifically the PRO MPPx model?
Thank you
Have you tried using Local Tuya with HACS?
It should work there.
I’m pulling my hairs here, i got a DFRobot RS485 connected to an ESP32, i do see TX and RX flicker on the board when i connect the cable right to the Mr. Pure, but i keep getting “Answer is too short: 1 byte”.
I ordered a USB RS485 and another RS485 board but maybe someone else had the same problem? Or is my Mr. Pure broken?
