Please select the remote and let me know?
Hi, Can you try v1.7.1
first off thanks for this it has helped me get 2 of my 4 AC units working in HA.
The issue i’m having is i’m trying to learn one of my units via the remote i go through the process and looking at the code in the end it’s all in one line. this what i’m getting.
“manufacturer”: “Kelvinator”,
“supportedModels”: [
“26hra”
“supportedController”: “Broadlink”,
“commandsEncoding”: “Base64”,
“minTemperature”: 24,
“maxTemperature”: 24,
“precision”: 1,
“operationModes”: [
“cool”
“fanModes”: [
“toggle”
“swingModes”: [
“toggle”
“commands”: {
“off”: “JgDKAI2REDYQFBA2EDcPFQ8VDzcPFQ8VDzcQFA8VDzcQNhAUEDYQFBA2EDYQNw83EBQPNxA2EDYQFBAUEBQQFBA2EBQQFBA2EDcPNw8VDxUPFQ8VDxQQFBAUEBQQNw83DzcQNhA2EK2NkRA2EBQQNhA3DxUPFQ83DxUPFQ83DxUPFQ83EDYQFBA2EBQQNhA2EDcPNxAUDzcQNhA2EBQQFBAUEBQQNhAUEBQQNhA2EDcPFQ8VDxUPFBAUEBQQFBAUEDYQNw83EDYQNhAADQU=”
yes that is what i’m using.
I also did the update today hoping it would work
Hi, no, same result :
Failed to perform the action fan.turn_on. Unknown error
I used your new codeset import inbox and worked perfect. Thx.
I keep adding questions but.. why hacs does not report there’s an update on this integration? … I have to check and redownload manually.
hello…first of all thank you for your amazing work. I try to add my Sharp AC (climate) to AR Smart IR but after selecting SHARP as manufacture, it only show one type/code (7300) in the model/code selection. I want to add code 1301 and i checked this json file is exist in /homeassistant/custom_components/ar_smart_ir/codes/climate/
I’m using S09-CB3S IR blaster connected using Tuya Local integration. Any suggestion?
Hi there! Thank you Please don’t select SHARP . Instead, select sharp (the one written in lowercase).
that’s it…thank you!!
another question…for power sensor to detect if my ac is on or off i create binary sensor template based on power usage of the AC power socket. but my climate card not change to off state when the binary sensor state is off..do you have better solution or suggestion for this power sensor?
Hi, I noticed the same issue. I just created 2 Automations to keep it in sync:
alias: Airco - MB Climate turned On (Sync the Switch)
description: ""
triggers:
- trigger: state
entity_id:
- climate.smartir_climate_mb
- "off"
conditions: []
actions:
- action: input_boolean.turn_on
metadata: {}
data: {}
entity_id: input_boolean.ac_mb
mode: single
and
alias: Airco - MB Climate Turned Off (Sync the Switch)
description: ""
triggers:
- trigger: state
entity_id:
to:
- "off"
conditions: []
actions:
- action: input_boolean.turn_off
metadata: {}
data: {}
mode: single
That does the trick for me.
you can try v1.7.3
You can try v1.7.3
I upgraded to the last version, same error with turn on.
action: fan.turn_on
percentage: 33
entity_id: fan.smartir_sankey_fan
Here is the log:
Logger: homeassistant.helpers.script.websocket_api_script
Source: helpers/script.py:540
First occurred: 09:22:20 (3 occurrences)
Last logged: 09:22:36
websocket_api script: Error executing script. Unexpected error for call_service at pos 1: SmartIRFan.async_turn_on() takes from 1 to 2 positional arguments but 3 were given
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 540, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1037, in _async_step_call_service
response_data = await self._async_run_long_action(
...<9 lines>...
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 650, in _async_run_long_action
return await long_task
File "/usr/src/homeassistant/homeassistant/core.py", line 2900, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2943, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 949, in entity_service_call
response_data = await _async_handle_entity_calls(
...<5 lines>...
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 828, in _async_handle_entity_calls
single_result = await entity.async_request_call(_with_context(entity, coro))
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1708, in async_request_call
return await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 823, in _with_context
return await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 907, in _handle_single_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/fan/__init__.py", line 315, in async_handle_turn_on_service
await self.async_turn_on(percentage, preset_mode, **kwargs)
TypeError: SmartIRFan.async_turn_on() takes from 1 to 2 positional arguments but 3 were given
ok and v1.7.4 ?
Bingo. It’s working now. You are the best!. Thanks a lot
This repository has been archived .
Thank you for all the improvements over the original!
Here’s hoping for a fork.
Yes, thanks a lot, it’s sad, it works easier and cleaner that HAIR does.
Unfortunately, due to HAIR posting in my GitHub issues and now adopting the IR code set, I’ve decided to archive the repository.
I appreciate everyone who contributed and supported the project. Going forward, I hope Mr. DAB-LABS REPO can provide further assistance
Understand. I get the future of the integration for IR and RF is going to be that way, but I really like the way this project handle things. Specially for Broadlink users that don’t work with the PRONTO protocol. Thanks again for your assistance.
