Arduino Nano ESP32 on ESPhome
The arduino nano esp32 did work with the Arduino IDE, with Visual Studio Code and Platformio, but no chance to download a build with ESPhome.
Configuration with ESPhome:
esp32:
board: arduino_nano_esp32
framework:
type: arduino
Any tips how this board works with ESPhome?
By the way is there a way to use the ESPhome library with Arduino or Visual Studio as IDE?
Quite detailed description of the problem…
Yes. Yaml code is just a text file you can edit from most text editors and IDEs. However the I in IDE usually means Integrated, and you may find difficulties with that when trying to invoke compiling the results for ESPHome use.
For what reason? :thinking:
What are you struggling with? :eyes:
It was solved by using the espressif library. You don't have to do anything, because the library esp-idf is used by esphome since 2025-12 or early 2026 release. Just use the latest release.
Did it took 4 months?
