Are there anyone running this adapter Develco Products A/S EMIZB-132
Hi I have this “Develco Products A/S EMIZB-132” adapter for reading my energy meter off the type Norwegian AMS.
This is a Zigbee adapter, but doesn’t have an device handler in ZHA. Can any one explain to me how to make one ?
I understand this is some sort off ZHAquirk, I have the information on which zigbee clusters it uses. But I don’t know how to connect this attributes to variables that are displayable in Home assitant in the correcct way.
Hi
Did you manage to get this working?
I have plugged this sensor, and I get strange data. Home assistant returns a smart energy metering that seems to be twice the active power. The most frustrating is that I can read total_active_power in the the clusters, but I have no idea how to get that into home assistant.
I have t his adapter too. The problem with this device is that it has a LOT of sensors, and they have values stored in the code with what you need to devide or multiply each sensor output to get the real output. I hope someone can make an integration for it but I have not found any yet that works.
I also bought this adapter and struggled with around 1,93 times the actual consumption (similar to @ben4790), actually I had agreed with Elektroimportøren to return the EMIZB-132 and exchange it for an EVA HAN-adapter tomorrow :slight_smile:
But I decided to do a bit more investigation this evening and with luck!
I dived into the diagnostics log for the device and located this:
            "attribute_name": "divisor",
            "value": 516
My math-head quickly translated that to around the same as 1000/516 = ca 1,93 :wink:
And yes, taking the summation_delivered / (1000/516) gave me pretty much the same total as on the display on the meter.
As I do not know how to set this attribute using ZHA Toolkit (should probably be possible), I made two new sensors using Helpers and the template integration:
{{ (states('sensor.emizb_132_instantaneous_demand') | float) * 516 / 1000 }}
{{ (states('sensor.emizb_132_summation_delivered') | float) * 516 / 1000 }}
Hopefully this can help others with this adapter. :slight_smile:
Hope I can add a follow-up question to this. I’m new to Home Assistant, so sorry in advance for any stupid questions.
Yesterday I moved from Futurehome to HA, and I was able to connect all my zigbee devices to Home Assistant.
However, the Develco EMIZB-132 returns some strange values. 7089 W was displayed in HA as “Instantaneous demand”, while the power meter display reported about 3.650 kW.
I saved a log file, and I see that the value 7089 is listed under “SmartEnergy Metering”. I also see in the file that “instantaneous_demand” has the value 3651, which matches the meter display.
Are there any way to read the correct parameter? Or maybe there is a conversion somewhere? I see that the divisor is 515 in my case, which matches the numbers I mention above. Is the configuration available, so I can see which parameters are actually used in HA?
