This blueprint will help you create a sensor that returns the count of open windows based on selected Areas. The entity IDs and Areas where there are open windows are available as attributes.
Features:
- Can track both windows and/or doors.
- Multiple Areas can be used. If no Area is provided, the sensor will cover all Areas.
- Specific windows and/or doors can be excluded.
blueprint:
name: Open Doors or Windows
description: |
The sensor's state returns a count of the number of open Doors and/or Windows.
Lists of their Entity ID's and the Areas with open windows are provided as attributes.
domain: template
author: Didgeridrew
homeassistant:
min_version: 2025.6.0
input:
inc_areas:
description: If used, only windows or doors in the selected Areas will be included.
default: []
selector:
area:
multiple: true
door:
description: Select whether doors should be included in this sensor.
default: false
selector:
boolean:
window:
description: Select whether windows should be included in this sensor.
default: true
selector:
boolean:
excluded_doors:
description: Any door entities selected will be excluded from the sensor's calculations.
default: []
selector:
entity:
multiple: true
filter:
- device_class: door
excluded_windows:
description: Any window entities selected will be excluded from the sensor's calculations.
default: []
selector:
entity:
multiple: true
filter:
- device_class: window
variables:
door: !input door
ex_doors: !input excluded_doors
window: !input window
ex_windows: !input excluded_windows
in_areas: !input inc_areas
area_ents: |
{% set in_areas = areas() if in_areas == [] else in_areas %}
{{in_areas|map('area_entities')|flatten|select('match', 'binary_sensor.')|list}}
ex_d: "{{[ex_doors] if ex_doors is string else ex_doors|default([],1)}}"
ex_w: "{{[ex_windows] if ex_windows is string else ex_windows|default([],1)}}"
area_doors: |
{{[] if not door else area_ents|select('is_state_attr','device_class', 'door')|list}}
area_windows: |
{{[] if not window else area_ents|select('is_state_attr','device_class', 'window')|list}}
state: "{{ this.attributes.open|count|default(0,1) }}"
attributes:
open: |
{% set exclusions = union(ex_w,ex_d) %}
{{ expand(union(area_windows, area_doors)|reject('in', exclusions))
|rejectattr('attributes.entity_id', 'defined')
|sort(attribute='last_changed', reverse=true)
|map(attribute='entity_id')|select('is_state','on')
|list }}
open_areas: "{{ this.attributes.open | map('area_name')|reject('eq', none) | unique | list }}"
availability: "{{ true }}"
Changelog:
2025-11-12: Modified template to sort open to make it easier to get the most recently opened window/door.
