I have an automation to look if it’s outside hotter/colder than inside.
I would like to make in generic as possible to be able to use it for all rooms.
I tested in the developer tools, but it looks like the trigger don’t work as axpected.
e.g
{{ area_name('sensor.thermostat_kuche_simon_temperature')}} {{floor_name('sensor.thermostat_kuche_simon_temperature')}}
result: Küche 1. Stock
Perfect!
Okay thought let’s implement it:
message: >-
Fenster auf! - Draußen ist es Wärmer als in {{
area_name('trigger.entity_id')}} {{floor_name('trigger.entity_id')}}
action: notify.matrix_harms_vorhop
Result:
Fenster auf! - Draußen ist es Wärmer als in None None
Why?
The complete automation:
alias: Test - Temperatur indoor vs outdoor
description: ""
triggers:
- entity_id:
- sensor.thermostat_kuche_simon_temperature
trigger: numeric_state
for:
hours: 0
minutes: 5
seconds: 0
below: sensor.ems_esp_boiler_outdoortemp
- entity_id:
for:
hours: 0
minutes: 5
seconds: 0
above: sensor.ems_esp_boiler_outdoortemp
- entity_id:
- sensor.schlafzimmer_shellytrv_simon_temperature
for:
hours: 0
minutes: 5
seconds: 0
- entity_id:
for:
hours: 0
minutes: 5
seconds: 0
conditions: []
actions:
- alias: Test mehr als 2 Fenster
if:
- condition: template
value_template: |-
{{ area_entities(area_name('trigger.entity_id'))
| select('match', 'binary_sensor.*fenster*') | list | count > 1 }}
then:
- action: matrix.send_message
metadata: {}
target: "!kieWnhLSTvrErkkdlP:matrix.org"
message: Mehr als 1 Fenster
- choose:
- conditions:
- condition: trigger
id:
- kaelter
sequence:
- if:
- condition: state
entity_id: input_text.vorhop_weather_forecast
state: warm
then:
- alias: Genau ein Fenster vorhanden? - warm
if:
value_template: |-
| select('match', 'binary_sensor.*fenster*') | list | count == 1 }}
then:
- alias: Fenster geschlossen?
if:
value_template: |2-
{{ states((area_entities(area_name('trigger.entity_id'))
| select('match', 'binary_sensor.*fenster*') | list)[0]) == "off" }}
then:
- data:
message: >-
Fenster geschlossen halten! - Draußen ist es Wärmer
als in {{ area_name('trigger.entity_id')}}
else:
- data:
message: >-
Fenster zu! - Draußen ist es Wärmer als in {{
else:
- data:
message: >-
else:
- alias: Genau ein Fenster vorhanden? - nicht-warm
if:
value_template: |-
then:
- alias: Fenster offen?
if:
condition: template
value_template: |2-
| select('match', 'binary_sensor.*fenster*') | list)[0]) == "on" }}
then:
- data:
message: >-
Fenster offen lassen! - Draußen ist es Wärmer als in
else:
- data:
message: >-
else:
- data:
message: >-
- conditions:
id:
- waermer
sequence:
- if:
- condition: state
state: warm
then:
if:
value_template: |-
then:
if:
condition: template
value_template: |2-
then:
- data:
message: >-
Fenster offen lassen! - Draußen ist es kälter als in
else:
- data:
message: >-
Fenster auf! - Draußen ist es kälter als in {{
else:
- data:
message: >-
else:
if:
value_template: |-
then:
if:
condition: template
value_template: |2-
then:
- data:
message: >-
Fenster geschlossen halten! - Draußen ist es kälter
else:
- data:
message: >-
Fenster zu! - Draußen ist es kälter als in {{
else:
- data:
message: >-
mode: parallel
max: 10
