Iβd need a unit to work with to support v5
I used to have the original case and loved your work. Just got a v5 and Pi5 and would really appreciate if you could help! Thanks in anticipation ![]()
Welcome. Thanks. I donβt have a unit to work with. I wouldnβt mind supporting it but I wonβt go out of my way to buy a unit just to add support.
My fan starts rattling really loud when below 10%, usually at 5%. Is there any way to implement a minimum fan speed? Iβd like the fan to only start when the curve reaches 10%, and not try to run below that in order to avoid this excessive noise.
You have need of new fans. The fans shouldnβt rattle at all. Replace your fans. The lowest setting is barely audible.
Hi, thanks for your work.
I use from almost 2 years now.
I am migrating my installation of HomeAssistant from HAOS to docker on my rpi5.
Thereβs any way to install this addon as another container in docker?
thanks again
Yeah. You could repackage it. At the end of the day, just like the original argon one, itβs just a shell script. But youβd need to do it. Iβm not supporting every configuration of hardware.
Can anyone help me:
ArgonOne Active Cooling Log:
Add-on: ArgonOne Active Cooling
Actively keeping your Argon One cool.
Add-on version: 30a
You are running the latest version of this add-on.
System: Home Assistant OS 16.2 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2025.10.2
Home Assistant Supervisor: 2025.10.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
Detecting Layout of i2c, we expect to see "1a" here.
ls: /dev/i2c-*: No such file or directory
Cannot find I2C port. You must enable I2C for this add-on to operate properly
And HassOS I2C Configurator Log:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
root
uid=0(root) gid=0(root) groups=0(root),0(root),1(bin),2(daemon),3(sys),4(adm),6(disk),10(wheel),11(floppy),20(dialout),26(tape),27(video)
/run.sh
total 4
drwxr-xr-x 18 root root 4020 Jun 25 14:17 .
drwxr-xr-x 1 root root 4096 Oct 18 22:34 ..
crw-r--r-- 1 root root 10, 235 Jun 25 14:17 autofs
drwxr-xr-x 2 root root 760 Oct 18 22:29 block
drwxr-xr-x 2 root root 60 Dec 31 1969 bsg
crw------- 1 root root 10, 234 Jun 25 14:17 btrfs-control
drwxr-xr-x 3 root root 60 Dec 31 1969 bus
drwxr-xr-x 2 root root 3080 Jun 25 14:17 char
crw------- 1 root root 5, 1 Oct 18 22:29 console
crw------- 1 root root 10, 123 Jun 25 14:17 cpu_dma_latency
crw------- 1 root root 10, 203 Jun 25 14:17 cuse
drwxr-xr-x 9 root root 180 Jun 25 14:17 disk
drwxr-xr-x 2 root root 80 Dec 31 1969 dma_heap
drwxr-xr-x 3 root root 120 Jun 25 14:17 dri
lrwxrwxrwx 1 root root 13 Jun 25 14:17 fd -> /proc/self/fd
crw-rw-rw- 1 root root 1, 7 Jun 25 14:17 full
crw-rw-rw- 1 root root 10, 229 Jun 25 14:17 fuse
crw------- 1 root root 254, 0 Jun 25 14:17 gpiochip0
crw------- 1 root root 254, 1 Jun 25 14:17 gpiochip1
crw------- 1 root root 238, 0 Jun 25 14:17 gpiomem
crw------- 1 root root 10, 183 Jun 25 14:17 hwrng
drwxr-xr-x 2 root root 60 Dec 31 1969 input
crw-r--r-- 1 root root 1, 11 Jun 25 14:17 kmsg
crw-rw-rw- 1 root 111 10, 232 Jun 25 14:17 kvm
lrwxrwxrwx 1 root root 28 Jun 25 14:17 log -> /run/systemd/journal/dev-log
crw-rw---- 1 root disk 10, 237 Jun 25 14:17 loop-control
brw-rw---- 1 root disk 7, 0 Jun 25 14:17 loop0
brw-rw---- 1 root disk 7, 1 Jun 25 14:17 loop1
brw-rw---- 1 root disk 7, 2 Jun 25 14:17 loop2
brw-rw---- 1 root disk 7, 3 Jun 25 14:17 loop3
brw-rw---- 1 root disk 7, 4 Jun 25 14:17 loop4
brw-rw---- 1 root disk 7, 5 Jun 25 14:17 loop5
brw-rw---- 1 root disk 7, 6 Jun 25 14:17 loop6
brw-rw---- 1 root disk 7, 7 Jun 25 14:17 loop7
drwxr-xr-x 2 root root 60 Dec 31 1969 mapper
crw-rw---- 1 root netdev 251, 0 Jun 25 14:17 media0
crw-rw---- 1 root netdev 251, 1 Jun 25 14:17 media1
crw-rw---- 1 root netdev 251, 2 Jun 25 14:17 media2
crw-rw---- 1 root netdev 251, 3 Jun 25 14:17 media3
crw-r----- 1 root kmem 1, 1 Jun 25 14:17 mem
drwxrwxrwt 2 root root 40 Dec 31 1969 mqueue
drwxr-xr-x 2 root root 60 Dec 31 1969 net
crw-rw-rw- 1 root root 1, 3 Jun 25 14:17 null
crw-r----- 1 root kmem 1, 4 Jun 25 14:17 port
crw------- 1 root root 108, 0 Jun 25 14:17 ppp
crw-rw-rw- 1 root tty 5, 2 Jun 25 14:17 ptmx
drwxr-xr-x 2 root root 0 Jun 25 14:17 pts
brw-rw---- 1 root disk 1, 0 Jun 25 14:17 ram0
brw-rw---- 1 root disk 1, 1 Jun 25 14:17 ram1
brw-rw---- 1 root disk 1, 10 Jun 25 14:17 ram10
brw-rw---- 1 root disk 1, 11 Jun 25 14:17 ram11
brw-rw---- 1 root disk 1, 12 Jun 25 14:17 ram12
brw-rw---- 1 root disk 1, 13 Jun 25 14:17 ram13
brw-rw---- 1 root disk 1, 14 Jun 25 14:17 ram14
brw-rw---- 1 root disk 1, 15 Jun 25 14:17 ram15
brw-rw---- 1 root disk 1, 2 Jun 25 14:17 ram2
brw-rw---- 1 root disk 1, 3 Jun 25 14:17 ram3
brw-rw---- 1 root disk 1, 4 Jun 25 14:17 ram4
brw-rw---- 1 root disk 1, 5 Jun 25 14:17 ram5
brw-rw---- 1 root disk 1, 6 Jun 25 14:17 ram6
brw-rw---- 1 root disk 1, 7 Jun 25 14:17 ram7
brw-rw---- 1 root disk 1, 8 Jun 25 14:17 ram8
brw-rw---- 1 root disk 1, 9 Jun 25 14:17 ram9
crw-rw-rw- 1 root root 1, 8 Jun 25 14:17 random
crw-rw-r-- 1 root root 10, 242 Jun 25 14:17 rfkill
brw-rw---- 1 root disk 8, 0 Jun 25 14:17 sda
brw-rw---- 1 root disk 8, 1 Jun 25 14:17 sda1
brw-rw---- 1 root disk 8, 2 Jun 25 14:17 sda2
brw-rw---- 1 root disk 8, 3 Jun 25 14:17 sda3
brw-rw---- 1 root disk 8, 4 Jun 25 14:17 sda4
brw-rw---- 1 root disk 8, 5 Jun 25 14:17 sda5
brw-rw---- 1 root disk 8, 6 Oct 18 22:29 sda6
brw-rw---- 1 root disk 8, 7 Jun 25 14:17 sda7
brw-rw---- 1 root disk 8, 8 Jun 25 14:17 sda8
drwxr-xr-x 4 root root 80 Jun 25 14:17 serial
drwxrwxrwt 2 root root 40 Oct 18 22:34 shm
drwxr-xr-x 3 root root 140 Jun 25 14:17 snd
lrwxrwxrwx 1 root root 15 Jun 25 14:17 stderr -> /proc/self/fd/2
lrwxrwxrwx 1 root root 15 Jun 25 14:17 stdin -> /proc/self/fd/0
lrwxrwxrwx 1 root root 15 Jun 25 14:17 stdout -> /proc/self/fd/1
crw-rw-rw- 1 root tty 5, 0 Jun 25 14:17 tty
crw--w---- 1 root tty 4, 0 Jun 25 14:17 tty0
crw--w---- 1 root tty 4, 1 Oct 18 22:29 tty1
crw--w---- 1 root tty 4, 10 Jun 25 14:17 tty10
crw--w---- 1 root tty 4, 11 Jun 25 14:17 tty11
crw--w---- 1 root tty 4, 12 Jun 25 14:17 tty12
crw--w---- 1 root tty 4, 13 Jun 25 14:17 tty13
crw--w---- 1 root tty 4, 14 Jun 25 14:17 tty14
crw--w---- 1 root tty 4, 15 Jun 25 14:17 tty15
crw--w---- 1 root tty 4, 16 Jun 25 14:17 tty16
crw--w---- 1 root tty 4, 17 Jun 25 14:17 tty17
crw--w---- 1 root tty 4, 18 Jun 25 14:17 tty18
crw--w---- 1 root tty 4, 19 Jun 25 14:17 tty19
crw--w---- 1 root tty 4, 2 Jun 25 14:17 tty2
crw--w---- 1 root tty 4, 20 Jun 25 14:17 tty20
crw--w---- 1 root tty 4, 21 Jun 25 14:17 tty21
crw--w---- 1 root tty 4, 22 Jun 25 14:17 tty22
crw--w---- 1 root tty 4, 23 Jun 25 14:17 tty23
crw--w---- 1 root tty 4, 24 Jun 25 14:17 tty24
crw--w---- 1 root tty 4, 25 Jun 25 14:17 tty25
crw--w---- 1 root tty 4, 26 Jun 25 14:17 tty26
crw--w---- 1 root tty 4, 27 Jun 25 14:17 tty27
crw--w---- 1 root tty 4, 28 Jun 25 14:17 tty28
crw--w---- 1 root tty 4, 29 Jun 25 14:17 tty29
crw--w---- 1 root tty 4, 3 Jun 25 14:17 tty3
crw--w---- 1 root tty 4, 30 Jun 25 14:17 tty30
crw--w---- 1 root tty 4, 31 Jun 25 14:17 tty31
crw--w---- 1 root tty 4, 32 Jun 25 14:17 tty32
crw--w---- 1 root tty 4, 33 Jun 25 14:17 tty33
crw--w---- 1 root tty 4, 34 Jun 25 14:17 tty34
crw--w---- 1 root tty 4, 35 Jun 25 14:17 tty35
crw--w---- 1 root tty 4, 36 Jun 25 14:17 tty36
crw--w---- 1 root tty 4, 37 Jun 25 14:17 tty37
crw--w---- 1 root tty 4, 38 Jun 25 14:17 tty38
crw--w---- 1 root tty 4, 39 Jun 25 14:17 tty39
crw--w---- 1 root tty 4, 4 Jun 25 14:17 tty4
crw--w---- 1 root tty 4, 40 Jun 25 14:17 tty40
crw--w---- 1 root tty 4, 41 Jun 25 14:17 tty41
crw--w---- 1 root tty 4, 42 Jun 25 14:17 tty42
crw--w---- 1 root tty 4, 43 Jun 25 14:17 tty43
crw--w---- 1 root tty 4, 44 Jun 25 14:17 tty44
crw--w---- 1 root tty 4, 45 Jun 25 14:17 tty45
crw--w---- 1 root tty 4, 46 Jun 25 14:17 tty46
crw--w---- 1 root tty 4, 47 Jun 25 14:17 tty47
crw--w---- 1 root tty 4, 48 Jun 25 14:17 tty48
crw--w---- 1 root tty 4, 49 Jun 25 14:17 tty49
crw--w---- 1 root tty 4, 5 Jun 25 14:17 tty5
crw--w---- 1 root tty 4, 50 Jun 25 14:17 tty50
crw--w---- 1 root tty 4, 51 Jun 25 14:17 tty51
crw--w---- 1 root tty 4, 52 Jun 25 14:17 tty52
crw--w---- 1 root tty 4, 53 Jun 25 14:17 tty53
crw--w---- 1 root tty 4, 54 Jun 25 14:17 tty54
crw--w---- 1 root tty 4, 55 Jun 25 14:17 tty55
crw--w---- 1 root tty 4, 56 Jun 25 14:17 tty56
crw--w---- 1 root tty 4, 57 Jun 25 14:17 tty57
crw--w---- 1 root tty 4, 58 Jun 25 14:17 tty58
crw--w---- 1 root tty 4, 59 Jun 25 14:17 tty59
crw--w---- 1 root tty 4, 6 Jun 25 14:17 tty6
crw--w---- 1 root tty 4, 60 Jun 25 14:17 tty60
crw--w---- 1 root tty 4, 61 Jun 25 14:17 tty61
crw--w---- 1 root tty 4, 62 Jun 25 14:17 tty62
crw--w---- 1 root tty 4, 63 Jun 25 14:17 tty63
crw--w---- 1 root tty 4, 7 Jun 25 14:17 tty7
crw--w---- 1 root tty 4, 8 Jun 25 14:17 tty8
crw--w---- 1 root tty 4, 9 Jun 25 14:17 tty9
crw-rw---- 1 root audio 188, 0 Oct 18 22:33 ttyUSB0
crw------- 1 root root 5, 3 Jun 25 14:17 ttyprintk
crw-rw---- 1 root 111 10, 125 Jun 25 14:17 udmabuf
crw------- 1 root root 10, 239 Jun 25 14:17 uhid
crw------- 1 root root 10, 223 Jun 25 14:17 uinput
crw-rw-rw- 1 root root 1, 9 Jun 25 14:17 urandom
drwxr-xr-x 3 root root 60 Jun 25 14:17 v4l
crw------- 1 root root 245, 0 Jun 25 14:17 vc-mem
crw------- 1 root root 10, 124 Jun 25 14:17 vchiq
crw------- 1 root root 10, 126 Jun 25 14:17 vcio
crw-rw---- 1 root tty 7, 0 Jun 25 14:17 vcs
crw-rw---- 1 root tty 7, 1 Jun 25 14:17 vcs1
crw-rw---- 1 root tty 7, 2 Jun 25 14:17 vcs2
crw-rw---- 1 root tty 7, 3 Jun 25 14:17 vcs3
crw-rw---- 1 root tty 7, 4 Jun 25 14:17 vcs4
crw-rw---- 1 root tty 7, 5 Jun 25 14:17 vcs5
crw-rw---- 1 root tty 7, 6 Jun 25 14:17 vcs6
crw-rw---- 1 root tty 7, 128 Jun 25 14:17 vcsa
crw-rw---- 1 root tty 7, 129 Jun 25 14:17 vcsa1
crw-rw---- 1 root tty 7, 130 Jun 25 14:17 vcsa2
crw-rw---- 1 root tty 7, 131 Jun 25 14:17 vcsa3
crw-rw---- 1 root tty 7, 132 Jun 25 14:17 vcsa4
crw-rw---- 1 root tty 7, 133 Jun 25 14:17 vcsa5
crw-rw---- 1 root tty 7, 134 Jun 25 14:17 vcsa6
crw-rw-rw- 1 root root 10, 122 Jun 25 14:17 vcsm-cma
crw-rw---- 1 root tty 7, 64 Jun 25 14:17 vcsu
crw-rw---- 1 root tty 7, 65 Jun 25 14:17 vcsu1
crw-rw---- 1 root tty 7, 66 Jun 25 14:17 vcsu2
crw-rw---- 1 root tty 7, 67 Jun 25 14:17 vcsu3
crw-rw---- 1 root tty 7, 68 Jun 25 14:17 vcsu4
crw-rw---- 1 root tty 7, 69 Jun 25 14:17 vcsu5
crw-rw---- 1 root tty 7, 70 Jun 25 14:17 vcsu6
crw------- 1 root root 10, 127 Jun 25 14:17 vga_arbiter
crw------- 1 root root 10, 137 Jun 25 14:17 vhci
crw-rw-rw- 1 root 111 10, 238 Jun 25 14:17 vhost-net
crw-rw-rw- 1 root 111 10, 241 Jun 25 14:17 vhost-vsock
crw-rw---- 1 root netdev 81, 0 Jun 25 14:17 video10
crw-rw---- 1 root netdev 81, 5 Jun 25 14:17 video11
crw-rw---- 1 root netdev 81, 7 Jun 25 14:17 video12
crw-rw---- 1 root netdev 81, 1 Jun 25 14:17 video13
crw-rw---- 1 root netdev 81, 2 Jun 25 14:17 video14
crw-rw---- 1 root netdev 81, 3 Jun 25 14:17 video15
crw-rw---- 1 root netdev 81, 4 Jun 25 14:17 video16
crw-rw---- 1 root netdev 81, 11 Jun 25 14:17 video18
crw-rw---- 1 root netdev 81, 9 Jun 25 14:17 video19
crw-rw---- 1 root netdev 81, 6 Jun 25 14:17 video20
crw-rw---- 1 root netdev 81, 8 Jun 25 14:17 video21
crw-rw---- 1 root netdev 81, 10 Jun 25 14:17 video22
crw-rw---- 1 root netdev 81, 12 Jun 25 14:17 video23
crw-rw---- 1 root netdev 81, 13 Jun 25 14:17 video31
crw------- 1 root root 10, 130 Jun 25 14:17 watchdog
crw------- 1 root root 247, 0 Jun 25 14:17 watchdog0
crw-rw-rw- 1 root root 1, 5 Jun 25 14:17 zero
brw-rw---- 1 root disk 254, 0 Jun 25 14:17 zram0
brw-rw---- 1 root disk 254, 1 Jun 25 14:17 zram1
brw-rw---- 1 root disk 254, 2 Jun 25 14:17 zram2
ls: /dev/i2c-1: No such file or directory
I don't see I2C.
mount: permission denied (are you root?)
Detected Protection Mode is enabled. Disable Protection Mode in Info Screen.
no sda1 config found
no sdb1 available
no mmcblk0p1 available
no nvme0n1p1 available
This Configurator did it's job. Perform a hard-power-off reboot now.
You will need to reboot twice total, once to place the files, and again to activate the I2C.
Iβm new to HA and struggling to get any of the options tow work on my RPi 5 / Argon One v5. The I2C configurator says that itβs done its job but I get errors when installing the cooling add-on. Here is what I get with the Argon One Active Cooling option (any ideas?):
[s6-init] making user provided files available at /var/run/s6/etcβ¦exited 0.
[s6-init] ensuring user provided files have correct permsβ¦exited 0.
[fix-attrs.d] applying ownership & permissions fixesβ¦
[fix-attrs.d] done.
[cont-init.d] executing container initialization scriptsβ¦
[cont-init.d] 00-banner.sh: executingβ¦
e[34m-----------------------------------------------------------e[0m
e[34m Add-on: ArgonOne Active Coolinge[0m
e[34m Actively keeping your Argon One cool.e[0m
e[34m Add-on version: 30ae[0m
e[32m You are running the latest version of this add-on.e[0m
e[34m System: Home Assistant OS 17.0 (aarch64 / raspberrypi5-64)e[0m
e[34m Home Assistant Core: 2026.1.3e[0m
e[34m Home Assistant Supervisor: 2026.01.1e[0m
e[34m Please, share the above information when looking for helpe[0m
e[34m or support in, e.g., GitHub, forums or the Discord chat.e[0m
[cont-init.d] 01-log-level.sh: executingβ¦
[cont-init.d] done.
[services.d] done.
Detecting Layout of i2c, we expect to see β1aβ here.
checking i2c port 0 at /dev/i2c-0
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: β β β β β β β β
10: β β β β β β β β β β β β β β β β
20: β β β β β β β β β β β β β β β β
30: β β β β β β β β β β β β β β β β
40: β β β β β β β β β β β β β β β β
50: β β β β β β β β β β β β β β β β
60: β β β β β β β β β β β β β β β β
70: β β β β β β β β
not found on /dev/i2c-0
checking i2c port 1 at /dev/i2c-1
00: β β β β β β β β
70: β β β β β β β β
not found on /dev/i2c-1
checking i2c port 13 at /dev/i2c-13
00: 08 09 0a 0b 0c 0d 0e 0f
10: 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f
20: 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f
30: β β β β β β β β 38 39 3a 3b 3c 3d 3e 3f
40: 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f
60: 60 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f
70: 70 71 72 73 74 75 76 77
not found on /dev/i2c-13
checking i2c port 14 at /dev/i2c-14
not found on /dev/i2c-14
I2C Port 255
Argon One was not detected on i2c. Argon One will show a 1a on the i2c bus above. This add-on will not control temperature without a connection to Argon One.
Current Temperature 104 Β°F
2026-01-27_15:33:51: 104F - Level 1 - Fan 0% (OFF)
Error: Could not open file /dev/i2c-255' or /dev/i2c/255β: No such file or directory
Failed 106: i2cset -y β${port}β β0x01aβ β${fanPercentHex}β
Safe Mode Activated!
Failed 217: return ${returnValue}
Current Temperature 102 Β°F
2026-01-27_15:34:21: 102F - Level 1 - Fan 0% (OFF)
After an update of home assistant i get this:
Add-on: ArgonOne Active Linear Cooling
Add-on version: 30a
System: Home Assistant OS 17.3 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2026.4.4
Home Assistant Supervisor: 2026.04.2
[cont-init.d] done.
[services.d] done.
00: -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
checking i2c port 10 at /dev/i2c-10
not found on /dev/i2c-10
checking i2c port 22 at /dev/i2c-22
/run.sh: line 116: thePort: unbound variable
not found on /dev/i2c-22
[cmd] /run.sh exited 1
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
