If you enable that option i told above, and Ariela detects VPN connection then the internal IP address will be used for connection (which i suppose that address is available via VPN). Can you confirm that Ariela is connecting to HA when your are over VPN connection?
Version 1.3.5.6 is out.
Whatâs new:
Version 1.3.5.6
Release date: 2 August 2019
- NEW: added proximity sensor
- NEW: added accelerometer sensor (state of the sensor will be device orientation)
- NEW: added distance setting between GPS locations
- Fixed camera streaming issue
- Fixed crash app when sending toggle requests
- Updated google libraries
Oh yea, I have been using your vpn integration. I use it every day and works perfect. (minus this new issue)
I just noticed this in the logsâŚim not quite sure how to resolve it though would you happen to know?
2019-08-02 04:24:37 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Received invalid webhook payload: required key not provided @ data[0]['state']. Got None
If you are trying to stream from Ariela (select a entity camera ) it will stream?
yea the same camera i am trying to send through notifications has been in ha for a long time, I have a couple ipads on the walls and they actually stream the cam all the time on lovelace. ive also viewed them on my phone.
Ok then if works in Ariela, please share the logs so i can check it out. Thank you.
Just sent it. Thank you!!!
Got it!!!
I didnt notice you could use entity name. I was looking at the example with the url for the cam. For some reason it doesnt work when using the same url i use to add it to ha but it works if i use the entity and thats good enough for me. Im really sorry to waste your time but I REALLY appreciate you walking through it and helping me!!!
I am glad to hear its working. Indeed entity_id is required in order to start streaming. In fact a url video stream should work also but depends if the format can be decoded or not by the phone
Oh thanks. Makes sense. I can stream that url right from chrome on my phone. No big deal at all this is easier:) thanks man. Ur app is awesome.
Thank you very much. I am glad you like the app
How to download the latest version ?
If didnât appear the latest version into play store, please wait a few hours and eventually will be there.
Ok Thanks, for light is it possible to choose the color ?
Yes. Just click on a light entity and a extended menu should appear.
I use love lace, I can switch on/off, dim but I donât see a menu.
Click next to the lamp icon (not on it, which would turn it on or off), press and hold for about a second, a menu will pop up.
Thanks it works
The last update fix the streaming for mjpeg camera component, thx.
Hello all,
Version 1.3.5.7 is out.
Whatâs new:
- NEW: Build in MJPEG front & back camera streaming
- NEW: French localization
- fixed mobile_app location update issue
Please test it and let me know how it goes. Thank you.
