Does the fix address my home some issue?
No, this release do not adding zone.home forced (if missing) in the home & wifi zone.
Version 1.3.5.8 is out.
What’s new:
- NEW: Added option to set startup page (tab) when using Web UI
- fixed invalid MJPEG streaming option description
- updated Google libraries
- fixed MJPEG crash while streaming
- add camera permission check when enabling MJPEG streaming
- fixed crash when pressing the widgets
- added toast when an error occur when pressing widgets
- fixed enabling groups issue in Lovelace entities card
Please test it and let me know if works. Thank you.
Hi the recent version I’m no longer able to configure mqtt. The app crashes when I try. Pixel 3 xl. Thank you.
This is what I get after entering my mqtt setup. I’ve had this working for a long time. Just reinstall Ed ha
Thank you for letting me know. I will fix this issue asap.
Awesome. Thank you!
Hello all,
Version 1.3.5.9 is out.
What’s new:
- NEW: Speech recognizer MQTT / Mobile_app sensor
- NEW: Home Assistant error log retrieval screen
- NEW: added settings quick access button when using web UI
- NEW: added setting option to disable / enable quick settings button
- fixed startup issue when device screen is off
- fixed issue when mobile_app registration does not happens
- fixed crash when setting up mqtt
- fixed issue when connecting for lower Android versions
Please test it and let me know how it goes. Thank you.
Im not seeing the update, does it take a day? I also now have the same mqtt crash issue on galaxy tab s5e
Seems that these days Google takes more time to check the apps / updates before deploying them to the users. I hope the update will be available on the store today.
AH ok cool. thank you
Still no update…
Just received that Ariela PRO update is available on store. I suppose Ariela FREE will be available next. Also more details about this you should find here: https://www.androidpolice.com/2019/08/19/google-play-expands-store-app-review/?fbclid=IwAR3piMVo1_hsHEHRu-C1ZTUKhPAtuAlw1gEkBzj5SHoboaQbMDiuGVfZrrY
I have pro I’ll check
Edit. Just got it. Works in my pixel xl 3 and tab s5e. Thank you.
I’m unable to make Ariela read NFC tags. What I can do to allow it to read NFC tags correctly?
Other apps can read tags without problems. My tag is recognized as NfcA tag in other apps.
Thanks,
PS
Thank you for letting me know. I will investigate the issue.
Version 1.3.6.0 is out.
What’s new:
- NEW: device tracker priority setting
- NEW: Chinese localization
- NEW: added new “time” attribute to NFC sensor
- NEW: add the possibility to choose server at startup
- fixed setup issue when 2FA cannot be processed
- fixed issue while loading local entity pictures
- improved server connection while Ariela not running in the background
- improved server connection with HTTP (not https)
- fixed issue where device name gets reset
- improved device tracker wifi mode
Please test it and let me know how it works.
The “No Power” option might need a better wording. Not sure what it is supposed to mean/do
No Power means that Ariela will not going to make direct queries to retrieve the location. Instead it will wait for other apps to do that and indirectly will receive the location too.
More info you can find here: http://ariela.surodev.com/2018/11/07/device-tracker/
Any new Wear OS changes on the Horizon? I am a huge fan of this app, but the Wear OS component could use a serious facelift
Not at the moment. Frankly, i have do not have any ideas of design improvements for the Wear, but you or anybody else can share something (a design , a picture , etc) i do not see why not implementing it.
