Ariela - Home Assistant Android Client - Updates Thread
I’ll see what I can come up with :slight_smile:
Hello all,
Version 1.3.6.1 is out.
What’s new:
  • NEW: motion detection sensor when using MJPEG streaming
  • NEW: added enable flash option when using MJPEG streaming
  • fixed issue when scroll to refresh option can’t be disabled
  • display lovelace title if available instead of “Dashboard”
  • improved MJPEG stream capabilities
  • fixed device tracker wifi issue when the default home wifi is not assigned to home zone
Please test it and let me know how it goes. Thank you.
In landscape mode for wall mounted tablet, the icons of sensor widgets are very small.
For heating widget, is it possible when moving the round on the circle to see the value changing? Because we don’t know when to release…
Can you post a screenshot regarding the widgets?
For the heating widget, what exacly you mean? Can you also share a screenshot?
Thank you.
Thank you very much for the screenshots. Now i understand what you mean. I will fix this issue on the next Ariela release.
Version 1.3.6.3 is out.
What’s new:
  • disable HANotify firebase notifications in mobile_app is supported
  • show thermostat Lovelace card update in realtime
  • improved badges rendering when running on tablets
  • enable Lovelace UI by default when the first run
  • added setting option to disable mobile_app push notifications for a device
  • rearrange notification settings
  • fixed weather card image issue loading
  • updated google libraries
  • small other fixes
Could you also add the mode of the heating ?
Of course. I will add this to my TODO list.
Version 1.3.6.4 is out.
What’s new:
  • NEW: added setting to ignore WiFi & Zones to rely on GPS data only
  • fixed issue where zone & wifi settings cannot be saved
  • updated Google libraries
Please test it and let me know how it works. Thank you.
The gauge widget seems not to take the severity color parameter into account.
Indeed the severity parameter is not taken into account. That fix is on my todo list
I have a conditional card, when condition is false, the card is not visible but it take the empty space…
That’s also a known issue :smiley:
Hello. I don’t understand why, the discovery for mqtt sensor repeats the name of the device.
Is it my configuration error or is it really so?
Thanks.
That name is not mandatory. You can change it to whatever you want. That repeating was introduced when the mobile_app sensors were available in the app. I didn’t changed since then the behavior since could break some things for some users.
Version 1.3.6.5 is out.
What’s new:
  • NEW: added unsupported Lovelace card view
  • minor UI changes to markdown Lovelace card
  • fixed issue when conditional card space is shown
  • fixed issue when the conditional card is still shown
  • show tabs name in uppercase
Dont really care for all the unsupported card messages. If you want to be notified which ones aren’t supported, create some other method to email them to you.
I will add a setting in Ariela that will allow hiding those items :slight_smile:
Ariela version 1.3.6.6 is out.
What’s new:
  • NEW: custom_card:ROKU support
  • NEW: custom_card:slider-entity-row support
  • NEW: custom:thermostat-card is displayed as thermostat card
  • minor fixes
  • minor UI changes regarding switches
