blauter
October 29, 2019, 5:22pm
424
Very much appreciated, thanks!
Also, does android let you pin permanent notifications to the top of the list. Minor request, but sometimes have to scroll quite a bit to find it
Skye
October 31, 2019, 4:21pm
425
Hi Ionut
Some issues I see:
This graphâs x-axis just counts up, no relation to the time
This image should show binary sensor bars:
The custom slider is not showing the slider:
The Xiaomi vacuum card is not filling its values:
See logs Iâve sent you by email
Ionut
(Ionut Cristea)
November 4, 2019, 1:02pm
426
Hello all,
Version 1.3.7.3 is out.
Whatâs new:
NEW: password protected settings
NEW: add HVAC buttons in thermostat Lovelace cards
add support for effect change for light entities
fixed xiaomi vacuum card info display issue
gray out device tracker / persons with status not_home
custom slider card improvements
change Settings screen to AndroidX compatible
fixed issue where groups cannot be turned off / on
Please test it and let me know how it works. Thank you
hello,
I have a feature request.
I am using a Lovelace alarm panel and there is no code necessary to arm/disarm.
The web UI does not show line to insert a code which is correct.
Ariella shows a code line and I can put any code to arm/disarm.
Can you make it the same as the web UI?
Skye
November 4, 2019, 8:13pm
428
Ionut:
Fixed
Ionut:
I still see no slider in Ariela for this card
Ionut
(Ionut Cristea)
November 5, 2019, 4:13am
429
Thank you for the suggestion. I will see what i can do about it.
Please send new Ariela logs so i can check it out.
moshe19803
(Moshe19803)
November 7, 2019, 9:55am
430
hi,
how can i set more then one wifi ssid to home location?
Ionut
(Ionut Cristea)
November 7, 2019, 10:05am
431
In Ariela -> Settings -> Device Tracker -> Wifi & Zones
there you could add wifi names and you should assign them to zone.home
After this, go to Ariela -> Settings -> Server Connection and enable âUse internal IP when connected to home APâ
If you do this, whenever Ariela detects you are connected to a Wifi which has assigned zone = âzone.homeâ it will automatically consider you home and it will use the internal IP address for connecting.
Please let me know if you have any issue with it.
Ionut
(Ionut Cristea)
November 7, 2019, 12:39pm
433
Version 1.3.7.4 is out.
Whatâs new:
NEW: Light Entity custom Lovelace card support
small changes regarding some entities default icons
SliderEntity row card slider position fix
hide alarm code entry if no code itâs required
Lovelace Alarm Card improvements
changed default firebase notification icon to Home Assistant logo
fixed issue when logs file not created on Android 10 devices
improved climate advanced options UI
fixed crash when tracking Lovelace Light card slider
fixed microphone sensor crash when sending update
better notification compatibility with Dark Mode when enabled in the system
add support for âmmâ unit of measurement graphs
updated Google libraries
Please test it and let me know how it goes. Thank you
moshe19803
(Moshe19803)
November 7, 2019, 12:43pm
434
hi,
i cant make ariela start running in the background after restart.
if i open the app then all is working.
ps
i still dident update to the new version
Ionut
(Ionut Cristea)
November 7, 2019, 1:11pm
435
I didnât make any updates on that area for some time:
What you should do:
Ariela -> Settings - >Common -> Start on boot
Ariela -> Settings - >Common -> Startup boot mode -> background service. Be sure that you also have the Ariela background service running enabled.
alarm code improvements! nice!
it works now as expected! thanks
moshe19803
(Moshe19803)
November 9, 2019, 9:27am
437
Can I install it on android TV?
Ionut
(Ionut Cristea)
November 9, 2019, 4:53pm
438
Yes you can install it, but it will be a little difficult to control it.
Ionut
(Ionut Cristea)
November 13, 2019, 10:13am
439
Hello all,
Version 1.3.7.5 is out.
Whatâs new:
NEW: Bignumber custom Lovelace card support
bump down Android version requirement to 4.0
add social links to about section of the app
add translation link to about section of the app
do not keep any settings in the case of app uninstall
fixed issue where Light entity info doesnât update
fixed app crash when sending alarm requests
Ionut
(Ionut Cristea)
November 14, 2019, 1:00pm
440
Hello all,
Version 1.3.7.6 is out.
Whatâs new:
NEW: background view support with beautiful parallax animation
NEW: move view tabs to the bottom
fixed color issue when dark mode enabled in the notifications area
fixed issue when loading local images
updated Russian localization
smoother loading experience when using WebUi mode
Please test it and let me know how it goes. Thank you.
Ionut
(Ionut Cristea)
November 21, 2019, 8:32am
442
Hello all,
Version 1.3.7.8 is out.
Whatâs new:
NEW: add posibility to hide a view in Ariela (eg: show only certain views on kids phones)
NEW: add possibility to trigger battery sensor updates from HA via mobile_app notifications
NEW: add WiFi selection possibility in the setup process
fixed crash when entering Settings
fixed issue with Android 10 device unable to add custom certificates
more work on slider entity custom card
small UI changes in notification items
small UI changes in shopping list
Ionut
(Ionut Cristea)
November 27, 2019, 7:14am
443
Hello all,
Ariela version 1.3.7.9 is out.
Whatâs new:
NEW: Wifi IP address device tracking
NEW: add setting to keep MQTT session independent of HA server
NEW: add posibility to trigger device tracker updates remotely
fixed issue when graphs decimal values are longer
fixed issue when graphs values & timestamps are not visible
fixed issue when internal IP is not used when home AP its detected
small other optimizations
