in my case there would be only 1 thing that would make it work in the future, and that is if ariela wouldnt depend on HA
i got all my automations in appdaemon, and except a few lose ends i already moved all my intergrations to appdaemon as well, and i am rewriting hadashboard to replace the HA frontend.
so i want to move away from HA completely this year.
the improvements sound very good though. i know other users will be glad with it!
Ionut
(Ionut Cristea)
December 30, 2020, 2:42pm
506
Hello
Ariela 1.4.0 is finally in the play store.
What’s new:
NEW: add possibility to change server from splash screen
NEW: add possibility to change dashboards
NEW: add possibility to set device name during initial setup
NEW: add entities search capabilities in the widget add screen
NEW: support toggling light entities from widgets
NEW: support toggling media player entities from widgets
NEW: redesign setup screens
NEW: support for entity lovelace card
NEW: support for button lovelace card
NEW: support for show_forecast flag in the weather-forecast cards
fixed setup issue when switching from http <-> https server
removed permanent notification
improved loading time
fixed switch server issue
fixed retrieving server URL issue
Lovelace thermostat card UI improvements
fixed issues with updating widgets states
weather-forecast card UI updates
Lovelace alarm card small UI updates
removed deprecated HANotify component support (use only mobile_app notifications instead)
show loading screen when trying to retrieve notifications
Download: https://play.google.com/store/apps/details?id=com.surodev.ariela
Please test it and let me know how it goes. Thank you
Ionut
(Ionut Cristea)
January 1, 2021, 8:56am
507
Ariela 1.4.2 is out:
What’s new:
NEW: added quick launch option entities display selection
NEW: added quick launch link on how to enable the function
NEW: added option to select the items visible on the Android Wear Watch
small UI changes
fixed app crash at startup
fixed memory leaks of current application settings
better Android Wear communication
Please test it and let me know how it goes. Thank you!
Ionut
(Ionut Cristea)
January 2, 2021, 8:28am
508
Hello everybody,
Version 1.4.3 is out.
What’s new:
NEW: Assistant mode (launch Ariela by long-pressing the Home key button)
NEW: Ariela Quick Launch setting to allow showing even when the phone is locked
NEW: Add Android Wear app install button the Ariela Settings
Fixed issue when the background mode is not activated
Tutorial - Ariela: Enable Assistant Mode
Tutorial - Access [#homeassistant ] server from the outside local network and without a dynamic DNS service using Ariela: Ariela: Access Home Assistant server without a dynamic DNS service – Ariela
Thank you.
Ionut
(Ionut Cristea)
January 5, 2021, 12:32pm
509
Version 1.4.4 is out:
What’s new:
NEW: display custom mini-media-player card as the default media player
add unit_of_measurement for battery sensor when sending info via MQTT
fixed incorrect entity icon display
fixed issue where the Camera streaming is not showing correctly
added input date/time card when using system-generated Lovelace config
fixed month calendar choosing issue for input date/time entities
fixed issue when Lovelace config is not retrieved on older HA versions
other fixes and improvements
Please test it and let me know how it goes. Thank you.
Ionut
(Ionut Cristea)
January 8, 2021, 8:06am
510
Version 1.4.5 is out.
What’s new:
NEW: added Estonian translation (thank you Repsionu)
NEW: add use internal IP option
fixed indefinite loading issue
scroll media title in media_player extended info
updated build tools and libraries
Ionut
(Ionut Cristea)
January 15, 2021, 12:21pm
511
Ariela 1.4.6 is out.
What’s new:
NEW: support for image header and footer attribute in groups
NEW: add support for multiwindow
NEW: headset sensor state (report if Headset is plugged in or not)
NEW: added connectivity sensor
Fixed display issues for group views
Fixed infinite loading issues during startup
Fixed issue when background running option is not correctly starting
updated Estonian translation
memory management improvements
Ionut
(Ionut Cristea)
February 26, 2021, 7:08am
512
Ariela 1.4.7 is out.
What’s new:
WebUI: fixed issue where the save login option is not accessible
WebUI: move the settings button to the left
WebUI: allow setting the startup dashboard (same as native UI rendering)
NEW: add support for visible attributes for views
fixed app crash when trying to create a new user
updated Google libraries
Thank you
