jwDave
(Dave)
1
I try to integrate my Arlo cameras with HA using the Aarlo config. After a while it says:
Success
Created configuration for Aarlo [email protected]
Then the integration says:
Failed to setup
Followed by:
aarlo Component Setup
Error: login failed: 429 - possible cloudflare issue
If error persists you might need to change config and restart.
I assume this later cloudflare issue is caused by too many attempted logins. I know the login details are correct.
Any suggestions?
jwDave
(Dave)
2
I think this integration is broken. I have tried so so many options and none work, I think it is an Arlo issue not a HA issue, for now I give up.
gre69g
3
I have the same problem Dave.
jwDave
(Dave)
4
Well it’s a small consolation to know I am not alone!
jrh1194
(John Hagan)
5
You’re definitely not alone with this issue. I’ve run into it also.
