2020-10-30 16:46:00 ERROR (SyncWorker_12) [pyaarlo] 2fa: no secondary choices available
2020-10-30 16:46:00 ERROR (SyncWorker_12) [custom_components.aarlo] Unable to connect to Arlo: 2fa: no secondary choices available
2020-10-30 16:46:00 ERROR (MainThread) [homeassistant.setup] Setup failed for aarlo: Integration failed to initialize.
2020-10-30 16:46:00 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform aarlo.alarm_control_panel: Unable to set up component.
2020-10-30 16:46:00 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform aarlo.binary_sensor: Unable to set up component.
What is secondary choices?
Edit: so after 5 reboots it decided to start working again…
Hi, this is going to be my first ever integration with my fresh home assistant install, ive gone as far as installing HACS and the AARLO integrations, but im sort of lost as to where to go from here… does this also need the Arlo integration to get going?
Thanks for the reply Steve, Im completely new to this… I’ve figured out that I need to add the configuration settings into my configuration.yaml but I am really struggling! are the any example configurations I can pillage and make my own? I’m trying to replace using the arlo ios app with the home assistant app with the same sort of functionality of getting notifications, live streaming and viewing recorded videos? later down the track once i’ve figured this out hoping to pipe it into deepstack too
Ah… found it was because I didn’t have spaces before my child objects in the configuration file, doh!
Have it up and running in the lovelace dashboard now woohoo… still have some configuration to go however… how to setup live view? currently can only access last recording.
I know this was asked a couple of times and reading through day 1 of this long thread until now, could not find a conclusive answer.
Is there a way to play the live stream immediately? The use-case I have is a Lovelace that is headless on a TV using CATT to send to the Chromecast. It has other RSTP cameras in a grid mode and is used as a security camera monitor. All feeds live.
Awesome! I would love to see your Lovelace layout become more standard with some of the other video services I use (WYZE/Nest), but this will be great and check off the last thing on my grid layout. Thanks for the hard work!
I have a problem setting up my Arlo Essential Spotlight (VMC2030) camera (without a base station). And i don’t see what i’m doing wrong. Suggestions are welcome.
My config:
#To alow video viewing camera
ffmpeg:
# Arlo Camera #
arlo:
username: [email protected]
password: xxxxxxxx
- platform: arlo
camera:
- platform: arlo
ffmpeg_arguments: '-pred 1 -q:v 2'
- platform: arlo
And the error:
Logger: homeassistant.setup
Source: components/arlo/__init__.py:57
First occurred: 11:27:53 (1 occurrences)
Last logged: 11:27:53
Error during setup of component arlo
File "/usr/src/homeassistant/homeassistant/setup.py", line 213, in _async_setup_component
result = await task
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/arlo/__init__.py", line 57, in setup
arlo_base_station = next((station for station in arlo.base_stations), None)
File "/usr/local/lib/python3.8/site-packages/pyarlo/__init__.py", line 172, in base_stations
return self.devices.get('base_station')
File "/usr/local/lib/python3.8/site-packages/pyarlo/__init__.py", line 187, in devices
for device in data.get('data'):
AttributeError: 'NoneType' object has no attribute 'get'
@sn33ky This thread is about aarlo a replacement for arlo. Assuming that’s what you want, and you’ve installedaarlo, you need to use aarlo in the configuration file.
