Article: Home Assistant Timers made easy
Using Home Assistant Timers involves quite a bit of repetitive YAML coding. Using templates and generators this can be made really easy.
See also my article Managing Home Assistant YAML config files for the environment that I use to develop my Home Assistant configuration.
