As the title says, any other way to restart after you have charged your config file without using Putty?
Re Dave
Re Dave
You could create a command line switch and have it restart the service using sudo systemctl restart home-assistant.service. I thought about doing this but decided to wait until it was fixed
From what I am experiencing systemctl restart will also timeout. The only way to truly stop/restart is to use kill -9.
I recently started rebuilding my hassbian because I thought this problem was particular to my setup. Didn’t see any other postings in the forum discussing this.
Same issue here - that’s the error message I get when I restart / try to check my script with hass --script check_config
Testing configuration at /home/homeassistant/.homeassistant
17-02-13 19:23:53 ERROR (MainThread) [homeassistant.loader] Unable to find component Configuration
Failed config
General Errors:
- Component not found: Configuration
Successful config (partial)
As I wrote in another thread - my config seems to work fine, it is in the right folder (I think) but the re-start process doesn’t find it.
If anybody has a solution on how to do this with a command line switch I’d be happy to use that instead of putty.
Tried to set it up myself but failed miserably
switch:
- platform: command_line
switches:
hass_restart_switch:
command_on: 'sudo systemctl restart home-assistant@homeassistant'
I’m probably thinking too simplistic here.
And being a Linux and HA noob doesn’t really help either.
Interesting. I haven’t had a problem restarting from an ssh session even after the GUI restart failed. I started with an all in one install on raspbian lite
sorry @heathpitts, misunderstanding here
I can re-start through an ssh session fine, np.
But a GUI re-start doesn’t work because the re-start process now includes the yaml-check. And because my fully functional configuration.yaml can’t be found it doesn’t execute.
Think I have found the problem with my restarts. As I mentioned have been rebuilding hassbian from scratch.
Adding various parts of the configuration.yaml back one piece at a time. Was having no issue with restarts until I added
- platform: bluetooth_tracker
After that restarts fail/timeout. Remove that line and restarts work again.
Can anyone else confirm ?
Seeing the same here. Installed platform: bluetooth_tracker
today. Didn’t notice any weird behavior so far in responsiveness, access through SSH, etc… Until my automatic restart at 3PM didn’t seem to work. I ended up doing a sudo reboot
which also took more time than usual (like at least a minute) to start executing. But eventually everything comes up again and responsiveness in the GUI is as usual. Must say I am not home right now, so cannot say whether the devices actually respond or not. But at least from what I can see, nothing indicates that they don’t.
Running Hassbian on the latest RPI.
UPDATE: after adding track_new_devices: false
, the restart of my HASS was as before again.
Just tested on 0.38.4
Adding
Causes the system to become slow ( command line lagg ) and restarts to fail.
Adding
Improves things a lot - ( less command line lagg but still some detected )
Restart still not right. Calling restart service responded faster but didn’t actually start the service properly. The original process id for hass was still showing in
sudo systemctl status -l [email protected]
but the service didn’t actually come back online. Had to kill it with
kill -9
then restart it using
sudo systemctl start [email protected]
I feel there is still an issue with using the bluetooth module so am going to remove it for now.
UPDATE: after adding track_new_devices: false, the restart of my HASS was as before again.
This to the bluethooth device tracker ???
