Assigning a templete value to a variable
I am trying to assign a template value to a variable to be used within a script but it returns a null value. I assume I have the syntax wrong.
This is how I am trying to assign a value:
variables:
  var_wled_effect: "{{ state_attr("light.wled_living_room", "effect_list") | random }}"
When I run this section nothing seems assigned to the variable (as in nothing is said after “Variable value is”):
service: tts.google_say
  entity_id: media_player.google_home_speaker
  message: Variable value is "{{ var_wled_effect }}"
This works, so I know the template is working:
  message: >-
    Effect selected "{{ state_attr("light.wled_living_room", "effect_list") | random }}"
Can anyone offer me any insight into how to assign a variable value from a template? Thanks in advance.
Your use of quotes appears to be incorrect.
  • If you use double-quotes inside a template, then you must use single quotes outside the template.
  • Alternatively, if you use single quotes inside a template then you must use double-quotes outside the template.
You’re using double-quotes inside and outside of the template.
Try it this way:
- variables:
    var_wled_effect: "{{ state_attr('light.wled_living_room', 'effect_list') | random }}"
- service: tts.google_say
    message: "Variable value is {{ var_wled_effect }}"
To illustrate why Taras’s advice is important, look how your template currently sees the open and closing of your quotes:
That’s all it sees.
That was indeed the problem. I thought if it worked in the last call (the last tts.google_say) it would work for the variable set as well.
Thanks for the feedback guys. Most awesome. Cheers.
That makes sense, thanks.
