Using Inject
i’m able to trigger a get entities
node that grabs sun.sun
In the debug node, I can change msg.payload
to msg.payload.0.attributes.elevation
to filter out everything but the elevation.
How, in a function
node, would I assign msg.payload.0.attriburtes.elevation
to a variable?
var sunLevel = msg.payload.0.attributes.elevation;
seems to be problematic because of the zero with a dot.
The end goal is to store the sun’s elevation in a global variable in NodeRED using:
var sunLevel = global.set('sunLevel', <elevation here>); // and then
var whatever = global.get('sunLevel');
if (this or that) {
whatever;
So, the syntax for:
needs work…or I need to know how to write a function from scratch that can yank this information out of home assistant without using the get entities
node.
EDIT: Looks like I figured this part out…is this the best way to do it? It seems to work.
const gHomeAssistant = global.get('homeassistant').homeAssistant;
msg.payload = gHomeAssistant.states[`sun.sun`].attributes.elevation;
Thanks!
