Assistance needed for Multical 603 and Multical 21 to be used with wmbusmeter
I “successfully installed” a iU891A-Xl dongle to my Homeassistant green.
It is detected, and it loks like it is running, I can configure new meters, using multical21 and kamheat as drivers. It automatically creates two MQTT instances but it keeps staying here (log)
[13:46:07] INFO: MQTT Discovery cleanup...
[13:46:08] INFO: Running wmbusmeters ...
Started auto iu891a[00202006] on /dev/ttyACM0 listening on t1
I thought it might take some time but as far as I know at least the water meter sends in a 16 seconds interval.
The Homeassistant is like 5m away from the meters and there is no blocking metal in between, they are behind wood but that usually should be an issue for the signal.
I am not quite sure where I could start to debug this.
Someone here with wmbusmeter and multical experience? :slight_smile:
Did you manage to solve this issue, or is it still current?
