Assistance with Vertical Stacks and Custom Cards
I’m fairly new to Lovelace, and I’ve been struggling a bit with two vertical-stack cards that are both part of the same main view.
Both vertical stacks contain custom cards, at least one of which (the alarm panel card) was loading properly previously.
Right now, for both of the vertical stack cards I’m getting the JS error:
“Cannot read property ‘states’ of undefined”
I’m hoping that someone can take a look at my YAML and see where I goofed (most likely in the spacing, but I just can’t see it).
Thanks!
      - type: vertical-stack
        title: Security
        show_header_toggle: true
        cards:
          - type: custom:alarm_control_panel-card
            entity: alarm_control_panel.home_alarm
            show_keypad: true
            title: Home Alarm
            style: '--alarm-color-disarmed: var(--label-badge-green);'
            states:
            - arm_home
            - arm_away
          - type: glance
            column_width: calc(100%/4)
            title: Mode
            entities:
              - entity: input_boolean.ha_mode_away
                tap_action: toggle
              - entity: input_boolean.ha_mode_home
                tap_action: toggle
              - entity: input_boolean.ha_mode_night
                tap_action: toggle
              - entity: input_boolean.ha_mode_vacation
                tap_action: toggle
          - type: entities
            entities:
              - binary_sensor.front_door
              - binary_sensor.deck_door
              - binary_sensor.garage_entry
          - type: picture-entity
            title: Front Door
            entity: camera.front_door
            camera_image: camera.front_door
            show_info: true
            tap_action: dialog
        title: Climate
        cards:
          - type: custom:ecobee-card
            entity: climate.home
          - type: weather-forecast
            entity: weather.dark_sky
assuming you’re on 0.81.0, there’s a nasty bug (red screens). Should be fixed soon with 0.81.1 hotfix.
Thanks @DavidFW1960. I appreciate the heads up. Is there a link to the GitHub bug report?
I think I was able to answer my own question. I’ll leave this here in case anyone else is looking for the GitHub bug report:
