Hi Folks,
I’d greatly appreciate your insights on time zones. I haven’t found an answer on my own and I’m just banging my head against the wall at this point.
tl;dr: I have a remote deployment on GMT-3, while my local time is GMT-5. When executing HA templates, some pick up my server time zone, while others pick up my local time zone… it is a mess.
Setup
Proxmox 6.8.12-5-pve VM running HAOS 14.2, core 2025.2.4.
root@pve00:~# date
Wed Feb 19 02:22:38 AM -03 2025
Proper HA time zone configured via
- Profile → Time Zone (Use Server Time Zone)
- Settings → System- > General (GMT-3)
HA terminal add-on output matches server local time after setting up NTP server for DHCP on my remote router using the right NTP pools/servers.
➜ ~date
Wed Feb 19 02:23:19 -03 2025
Challenges
Some templates work great… others drive me crazy. In particular when trying to display an hourly weather forecast.
Working great:
{{ now() }}
2025-02-19 02:23:47.809414-03:00
Working awfully
{{ now().now() }}
2025-02-19 00:23:47.809432
{{ now().astimezone() }}
2025-02-19 00:23:47.809438-05:00
astimezone()
is currently using the same time as the naive approach, which is actually my local time zone - two hours behind the server time zone.
Furthermore:
{{ utcnow().tzinfo }}
UTC
{{ now().tzinfo }}
America/Santiago
{{ now().astimezone().tzinfo }}
EST
If I try to get the weather forecast for the next hour, I get it on my local time zone, instead of the server time zone… needless to say, this is absolutely useless to me.
{% set forecast_time = (state_attr('sensor.forecast', 'forecast') | map(attribute='datetime') | list)[0] %}
{% set dt = strptime(forecast_time, '%Y-%m-%dT%H:%M:%S%z') %}
{{ dt.astimezone().strftime('%-I%p %z').strip() }}
1AM -0500
The expected output above should’ve been 3AM -0300.
What I’ve tried
- Configuring Chrony to set up the system clock. Chrony log shows:
[02:05:12] INFO: Starting chronyd...
2025-02-19T05:05:12Z chronyd version 4.6.1 starting (+CMDMON +NTP +REFCLOCK +RTC +PRIVDROP +SCFILTER +SIGND +ASYNCDNS +NTS +SECHASH +IPV6 -DEBUG)
s6-rc: info: service legacy-services successfully started
2025-02-19T05:05:12Z Initial frequency -205.829 ppm
2025-02-19T05:05:16Z System's initial offset : 0.045135 seconds slow of true (slew)
2025-02-19T05:05:23Z Selected source 64.176.3.116 (cl.pool.ntp.org)
- Setting up DHCP NTP server on remote router
- reconfiguring and resetting everything through the GUI.
Yet, I still get astimezone()
modifying server time zone by -5 instead of -3.
Request
All the posts I’ve found with a similar problem seemed to have been solved by the steps above - or at least these were the proposed solutions… If you can point me to any other solution, I’d greatly appreciate it.
Thank you very much in advance.
