Still failing in 87.0
Unable to read from router on 192.168.1.1:23
If you are using non standard ports indicate it on yaml configuration file.
For me it’s working fine in all 0.87 versions for ssh using key
Could you help elaborate your setup, and maybe share a snippet of your yaml?
Also when you say working fine. Are we talking about both device tracker and asuswrt sensor?
I just upgraded to .87 and was able to get asuswrt to load without errors. I’m getting devices in my known_devices.yaml and the ones I’ve manually marked track: true are showing up in my devices list. Here’s my code;
asuswrt:
host: 192.168.1.1
username: admin
password: !secret asus_password
protocol: ssh
port: 22
device_tracker:
- platform: asuswrt
host: 192.168.1.1
username: admin
new_device_defaults:
track_new_devices: false
hide_if_away: false
that’s exactly how I’ve got mine setup and working.
Not sure whether thats correct as it goes against what the documentation says for the device tracker:
“The platform will be automatically configured if Asuswrt component is configured.”
but, I suspect either the documentation needs to be updated, or something needs to be rethought, as you often want to add extra parameters to the device tracker such as the new_device_defaults
, or consider_home
, etc. Also feels wrong having the credentials twice, but given it’s working, I haven’t had the heart to mess around with it given the instability!
Here is my setup. Tracker & sersors works, but I’ve sensors ignored because I don’t want it:
asuswrt:
host: 192.168.1.1
username: !secret asuswrt_login
ssh_key: rsa_key
port: 22
protocol: ssh
- platform: asuswrt
interval_seconds: 30
consider_home: 90
hide_if_away: false
discovery:
ignore:
- igd
And still working after some hours? I read in other topic sensor stops working after some hours
Yes, it’s now working for me since yesterday (aprox 20hr) when I updated to 0.87.0.
This is my yaml
asuswrt:
host: 192.168.1.1
username: admin
password: myrealpassword
protocol: telnet
port: 23
sensors: []
device_tracker:
- platform: asuswrt
# host: 192.168.1.1
# username: admin
# password: myrealpassword
# protocol: telnet
# port: 23
consider_home: 360
The host, username, password, protocol and port are commented out from the device tracker as noted in the documentation
When I restart my hassio, sometimes works for some time and the errors again
Per this, looks like it is/was related to the openssl that hass.io calls.
https://github.com/home-assistant/home-assistant/issues/20513#issuecomment-460245975
So just checking - is everyone here that gets asuswrt working under hass.io?
I’m using Docker and it stops working after a few hours with the following configuration:
asuswrt:
host: 192.168.2.1
username: xxxxx
password: xxxxx
but now that @GoNzCiD says that it has been working for him for 20 hours, I’m going to try to authenticate with RSA.
I’ll let you guys know how it goes…
Okay it stopped working after 12 hours … it’s a shame.
At least it doesn’t work for me.
Is it the device tracker that stops working?
Have you tried defining a separate device tracker as the above examples show?
Do you get any errors in the ha log after the failure?
Thanks for asking… I haven’t tried to set up a separate device tracker yet, but I’m gonna give it another try.
I’m getting these errors:
2019-02-08 05:01:14 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:00:12
2019-02-08 05:01:27 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:00:12
2019-02-08 05:01:40 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:00:12
2019-02-08 05:01:53 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from asuswrt took longer than the scheduled scan interval 0:00:12
maybe you have any problem with the router/lan configuration and you are getting a timeout, I’ve been watching my logs and I can see it’s asking about every 10-15 seconds.
My router is an AC87U and I use merlin firmware.
asuswrt tracker is working for 5 days for me in 0.87.0 running in docker.
Perhaps the Asus or Merlin firmware could be the culprit. From the release notes for the latest Asuswrt Merlin firmware 384.9:
- KNOWN ISSUE: Networkmap listing may be unreliable.
(Bug in Asus's code)
Edit: apparently Asus changed the code that determines which clients are connected. Now not all connected clients are showing up in the list. Mentions on the SNB forum are confirming the issue.
Okay this is my config:
asuswrt:
host: 192.168.2.1
username: xxxx
ssh_key: '/config/ssh/asuswrt'
port: 22
protocol: ssh
Then I added a separate device tracker:
device_tracker:
- platform: asuswrt
interval_seconds: 15
consider_home: 90
hide_if_away: false
It has been working for the past 18 hours, so let’s cross our fingers.
I haven’t updated the software on my router because of that… Actually I have the previous firmware.
keep us posted
