Atom Echo - Play Timer Audio On Another Speaker
Hello All,
For voice assistant testing i am using an Atom Echo, i have already changed the tts output so it uses another speaker and i have muted the device.
using the ESPHome Builder in the “atom-echo.yaml” file i have the following but it never plays on the media_player.living_room_2 is never triggered
      # Turn on the repeat mode and pause for 1000 ms between playlist items/repeats
      - lambda: |-
            id(echo_media_player)
              ->make_call()
              .set_command(media_player::MediaPlayerCommand::MEDIA_PLAYER_COMMAND_REPEAT_ONE)
              .set_announcement(true)
              .perform();
            id(echo_media_player)->set_playlist_delay_ms(speaker::AudioPipelineType::ANNOUNCEMENT, 1000);
      - media_player.speaker.play_on_device_media_file:
          media_file: timer_finished_wave_file
          announcement: true
      - homeassistant.service:
          service: media_player.play_media
            entity_id: media_player.living_room_2
            media_content_id: https://xxxxx.com/local/media/sta_blackalert.mp3
            enqueue: replace
            media_content_type: audio/mp3
            announce: "true"
      - delay: 15min
      - switch.turn_off: timer_ringing
Any help would be appreciated
