Atom Echo with own wakeword stucks after single usage
I followed this guide https://www.home-assistant.io/voice_control/thirteen-usd-voice-remote/
and was succesful in setting up my Atom echo and “Ok Nabu”.
Normally a red LED is glowing when the speaker is idle and it shifts to bluew when the wake word is detected.
After I got it working I started to train my own wake word but it did not recognise it.
After a while I found out to switch “Wake word engine location” to “In home assistant”.
The usually red led is now light blue.
It detects my new wakeword and reacts accordingly, and switiches to a blue led while listening.
However after the first detection it does not react to my wakeword until I press the button on the device and now it works for one more time.
I did not find any cases where the button is involved in the problems.
Anyone has a hint whats wrong here?
nils
Found the solution.
I had to edit the else part after the device answered.
  - id: start_wake_word
    then:
      - wait_until:
          and:
            - media_player.is_idle:
            - speaker.is_stopped:
      - if:
          condition:
            lambda: return id(wake_word_engine_location).state == "On device";
          then:
            - voice_assistant.stop
            - micro_wake_word.stop:
            - delay: 1s
            - script.execute: reset_led
            - script.wait: reset_led
            - micro_wake_word.start:
          else:
            - if:
                condition: voice_assistant.is_running
                then:
                  - voice_assistant.stop:
>>>>>>>>>>>>>>>new <<<<<<<<<<<<<<<<<<<<<<<<
                  - delay: 500ms
                  - lambda: id(va).set_use_wake_word(true);
            - voice_assistant.start_continuous:
