AttributeError: module 'lib' has no attribute 'SSL_ST_INIT'
First time hass installer here
right after i install pip3 & home assistant, I execute the ‘hass --open-ui’ and it throws this error:
File “/usr/local/bin/hass”, line 11, in
sys.exit(main())
File “/usr/local/lib/python3.5/dist-packages/homeassistant/main.py”, line 349, in main
args = get_arguments()
File “/usr/local/lib/python3.5/dist-packages/homeassistant/main.py”, line 90, in get_arguments
import homeassistant.config as config_util
File “/usr/local/lib/python3.5/dist-packages/homeassistant/config.py”, line 23, in
from homeassistant.core import callback, DOMAIN as CONF_CORE
File “/usr/local/lib/python3.5/dist-packages/homeassistant/core.py”, line 41, in
import homeassistant.util.location as location
File “/usr/local/lib/python3.5/dist-packages/homeassistant/util/location.py”, line 10, in
import requests
File “/usr/local/lib/python3.5/dist-packages/requests/init.py”, line 52, in
from .packages.urllib3.contrib import pyopenssl
File “/usr/local/lib/python3.5/dist-packages/requests/packages/urllib3/contrib/pyopenssl.py”, line 46, in
import OpenSSL.SSL
File “/usr/lib/python3/dist-packages/OpenSSL/init.py”, line 8, in
from OpenSSL import rand, crypto, SSL
File “/usr/lib/python3/dist-packages/OpenSSL/SSL.py”, line 118, in
SSL_ST_INIT = _lib.SSL_ST_INIT
AttributeError: module ‘lib’ has no attribute ‘SSL_ST_INIT’
