You’re not in the US though right?
No, Europe.
Yeah it’s the US people who can’t connect.
Wonder if there is a possibility this is fixed. Looks like arjenvrh hasn’t posted here for 6 months or so. Yet looks like 28 days ago there was some change for APIs for newer cars in git.
Hi mittlerweile funktioniert die Hacs Integration sehr gut.
Ich habe einen Audi A5 Baujahr 2020
Ich habe 21 Entitäten.
Hi meanwhile the Hacs integration works very well.
I have an Audi A5 built in 2020
I have 21 entities.
Great work on this integration! But I am in the same situation here! Seems like it started the last couple of updates. I have tried everything I can think to try. I deleted the integration and reloaded it several times. It keeps saying invalid credentials! I have updated my password and that still does not have an effect. Such a great integration, hate not having it work! I had it set up to notify me when a window or door was left open, fuel was low, if unlocked away from home it would automatically lock itself, etc. Very useful tool!
getting the same issue
HA: 2021.5.3
cancel that
i did a reboot of HA and its working fine now
Couldn’t get past your hidden profile and your picture shooting an assault rifle. You in the US as I’m not seeing this functioning. Updated to 2021.5.3 and restarted and still failing to login.
Sorry, UK based but image is from a trip to the USA
What config are you applying when you set it up?
Did you add the 8 pin code from your Audi app?
I am in the US I only have a 4 digit pin code? It has S-code but the only pin code I am aware of on myaudi is one that is 4 digit.
It should be longer than that I think
It’s not your pin
It’s the Audi assigned Pin
In your Audi app
Go to account
Then vehicle connection
Then scroll down to see your MyAudiPin
Use that
Doesnt work for the US, it’s not tied to the spin, the API that we’re pointed at is flat out rejecting out logins, it started after the maintenance window they had where they changed everything over.
Won’t work but I’m trying to redo it from scratch. Been a while since I did this so confusing. I have one email address that is tied to myaudiconnect.com. THis is an account setup while at the dealership. HOwever on the Audi app, it’s using my other email address. Then there is some other Audi website that uses the same email address as I use in the app.
With my login on the mobile app I do not see the pin there. I do have some kind of pin under account settings but that’s 4 digits. I also have a card from Audi that says myAudi App PIN and also has a 4 digit pin which is probably the same. Only have the option to change it in the app, not see it.
In the end the integration says the pin is optional but setting up the account fails with or without one. Guess that’s the good and bad of community platforms. Lots of new things but chances are eventually they may stop being maintained.
its a pain to find, but its there.
In your audi app, open it up and click on the person (account)
then go to “vehicle connection” option
then scroll down to “personalised services” - that should give you the 8 code “myAudi Pin”
i deleted everything then re-added using that.
it works fine now
That’s good but remember this is a US problem and looks like you are in the UK. I confirmed in the US the code is 4 digits and is optional anyway. Just entering your username and password in the add-on fails. Hopefully someone will pick this up. Maybe I will take a look but never coded anything for HA before.
I am in the US and this seemed to work perfectly with my 18’ Q5. But after the last couple of updates, it stopped working. @arjenvr did an excellent job of creating this integration! It was one of my favorites! I had at least a dozen automations set up to do everything from notifying me if the windows were left open or the car was unlocked away from home. If the car was away from home and unlocked I had it programmed to lock automatically after a certain time. It would tell me when I needed gas etc.
I have no computer/programming skills but have learned a lot setting up HA and I am willing to do whatever is needed to assist in getting this working again in the US!
For me, the Locking/Unlocking doesn’t work at all. When I do that from myAudi app, it always goes through the PIN entry, like this:
but I don’t think this adds-on do that at all, resulting temporary suspension on the service for an hr. or so. Anyone seeing this at all??
-S
Been using this integration for quite a while now, and while it works great most of the time, there are a couple of things I’d love to get some input on;
If I restart Home Assistant while my e-tron is not connected and charging, the entities sensor.car_charging_power and sensor.car_charging_rate does not get created. Not even if I connect and charge the car at a later time. They are simply not there until HA is then restarted once more while it’s charging. Is there any workaround to this, other than timing all restarts of HA to when the car’s charging?
I am not able to start climatisation using the service audiconnect.execute_vehicle_action, but, and this is the fun part, I am able to stop it if I have started the climatisation using for example the myAudi app on my phone. Anyone else with the same problem? How did you solve it?
Thanks.
@albatorsk - so, vehicle Lock/Unlock from HA working for you without any issue? Or you haven’t tried that yet? Dose it pop-up the PIN-entry screen or is it working without it? Any help/comment would be appreciated!!
