Help needed figuring out why there’s no sound from the Adafruit PCM5102 DAC configured as I2S_Speaker, running on an Adafruit Feather32 Huzzah (a WROOM32-E, not a v2, not -C, etc).
The project is going to be a Cuckoo Clock, with on-device sounds played on a small speaker. I have a 2.5W amp downstream of the DAC output.
I’ve tried all the recipes and relevant previous posts here that I can find, but nothing changes.
The config:
# i2s_test.yaml
# using Adafruit PCM5102 DAC https://www.adafruit.com/product/6250
# created .h file by following https://esphome.io/guides/audio_clips_for_i2s/
i2s_audio: # https://esphome.io/components/i2s_audio/
- id: i2s_audio_bus
i2s_lrclk_pin: GPIO19
i2s_bclk_pin: GPIO17
speaker: # https://esphome.io/components/speaker/i2s_audio/
- platform: i2s_audio
i2s_audio_id: i2s_audio_bus
i2s_dout_pin: GPIO16
dac_type: external
button:
name: "Play Sound on Speaker"
on_press:
- logger.log: Speaker Button Pressed
- speaker.mute_off:
- speaker.volume_set:
volume: 100%
- speaker.play:
data: !lambda return timer_finished_raw;
- platform: restart
internal: false
esphome:
includes:
- cuckoo/timer_finished.h
esp32:
# board: featheresp32
variant: esp32
framework:
type: esp-idf
logger:
baud_rate: 115200
level: DEBUG
logs:
text_sensor: INFO
sensor: INFO
ota:
- platform: esphome
- platform: web_server
wifi:
min_auth_mode: WPA2
fast_connect: false
networks:
- ssid: !secret wifi_ssid
web_server:
version: 3
port: 80
include_internal: true
api:
The log:
[D][button:022]: 'Play Sound on Speaker' Pressed.
[D][main:306]: Speaker Button Pressed
[D][i2s_audio.speaker:102]: Starting
[D][i2s_audio.speaker:106]: Started
[D][ring_buffer:034][speaker_task]: Created ring buffer with size 16000
[D][i2s_audio.speaker:111]: Stopping
[D][i2s_audio.speaker:116]: Stopped
